reschl
Invalid access to memory (on windows xp pro sp3)
ia always get an 'Invalid access to memory' on my win xp pro sp3 using commander interface after successfully login to any server.
- Guest
log:
* 2008-11-27 11:28:58.890 (EAccessViolation) Access violation at address 006825E0 in module 'WinSCP.exe'. Read of address 00000124
Site Admin -
- 43,055
- Prague, Czechia
Re: Invalid access to memory (on windows xp pro sp3)
What version of WinSCP are you using?
- Guest
oh, sorry, i forgot that information.
Version 4.1.7 (Build 413)
Chris R
Invalid Access to Memory
I also receive the Invalid Access to Memory on both my XP Pro Server, and XP Pro Media Center SP3 systems. I never received the error in 4.1.6, but since upgrading to 4.1.7, it occurs after about 20-25% of uploads. I have noticed that immediately following an upload is the most common time that the error does occur, however, I have seen it occur mid-upload, and also at random times when I was not even focused on WinSCP. I uninstalled 4.17 and downgraded to 4.16 and now the error occurs even in version 4.16.
Site Admin -
- 43,055
- Prague, Czechia
Re: Invalid Access to Memory
Can you provide me your email address, so I can send you a debug version of WinSCP to track the problem? If you do not want to post the address here, you can send me an email. You will find it (if you log in) in my forum profile. Please include link to this topic. Thanks.I also receive the Invalid Access to Memory on both my XP Pro Server, and XP Pro Media Center SP3 systems. I never received the error in 4.1.6, but since upgrading to 4.1.7, it occurs after about 20-25% of uploads. I have noticed that immediately following an upload is the most common time that the error does occur, however, I have seen it occur mid-upload, and also at random times when I was not even focused on WinSCP. I uninstalled 4.17 and downgraded to 4.16 and now the error occurs even in version 4.16.
- reschl
- 1
@prikryl
you can send me a debug version, too, if you like.
but i can not see your email addy in your profile, even when i am loged in.
Chris R
@ prikryl
you can send a copy to <email_removed>, thanks
Site Admin -
- 43,055
- Prague, Czechia
This bug has been added to tracker.I also receive the Invalid Access to Memory on both my XP Pro Server, and XP Pro Media Center SP3 systems. I never received the error in 4.1.6, but since upgrading to 4.1.7, it occurs after about 20-25% of uploads. I have noticed that immediately following an upload is the most common time that the error does occur, however, I have seen it occur mid-upload, and also at random times when I was not even focused on WinSCP. I uninstalled 4.17 and downgraded to 4.16 and now the error occurs even in version 4.16.
Site Admin -
- 43,055
- Prague, Czechia
This bug has been added to tracker.you can send me a debug version, too, if you like.
