Abnormal Program Termination
chuck
I am getting Abnormal Program Termination for WinSCP v.3.3.0 (build 177).
I uninstalled, re-downloaded Windows install program, re-installed, rebooted various times. No change. Help please
Chuck
Here is the session log: (Host Key Fingerprint and User Name were Deleted)
. WinSCP Version 3.3.0 (Build 177)
. Login time: Tuesday, September 23, 2003 11:07:33 PM
. Session name: RICH2
. Host name: richclub.org (Port: 22)
. User name: DELETED (Password: Yes, Key file: No)
. Transfer Protocol: SFTP
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes
. Ping interval: 0 sec (0 = off); Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: d:\updates, Remote directory: home, Update: No, Cache: Yes
. Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. Looking up host "richclub.org"
. Connecting to 216.74.117.213 port 22
. Server version: SSH-1.99-Foxit-WAC-Server-1.4
. We claim version: SSH-2.0-WinSCP-release-3.3.0.177
. Host key fingerprint is:
. ssh-dss ***DATA DELETED***
! Using username "DELETED".
. Sent password
. Access granted
. Opened channel for session
. Primary command failed; attempting fallback
. Started a shell/command
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
> Type: SSH_FXP_REALPATH, Size: 10, Number: 16
. Closing connection.
Re: Abnormal Program Termination
Sorry, but currently I have no idea :-(
Have you tried SCP instead of SFTP? Can you create test account for me on your server?
