FTP automation from the commandline
When I use ftp://ipaddress then I can connect but I can't do automation (since I'm using the url) But if I don't use the URL it won't connect even if I use ipaddress:portnumber. How does winscp know what protocol to use when not using the url prefix?
Cheers,
Rhys
Re: FTP automation from the commandline
You can use the URL prefix in "open" command in script (what is preferred anyway) instead of opening session from command line.
