Auto Upload
Schursch
Frankfurt am Main (Germany)
Auto Upload
Hi all,
I am using WINSCP 3.6.8. and I want to upload an Excel-File by VBA automatically.
... Shell("C:\Program Files\WinSCP3\WinSCP3.exe upload@prod.gb.users.com /upload C:\test_file.xls /home/uploads/)")
It works fine until the message-box (Copy) appears where I have to confirm it manually.
It would be nice if someone knows how to disable the message box or how to change the command.
Thanks in advance and kind regards,
Schursch
Highage
I am attempting this too
here is part of my code:
Print #lInt_FreeFile01, "option batch on"
Print #lInt_FreeFile01, "option confirm off"
Print #lInt_FreeFile01, "open xxx.xxx.edu"
Print #lInt_FreeFile01, "xxxx"
Print #lInt_FreeFile01, "cd public_html/"
Print #lInt_FreeFile01, "option transfer binary"
Print #lInt_FreeFile01, "put " & ThisWorkbook.Path & "\jw\test1.txt"
but still search on ...
Re: I am attempting this too
And what problem do you have?
Highage
MO
I figured out. Thanks Admin.
I tested back and forth and figured out. I used windows FTP command to set up a VBA module to do auto FTP a few days ago. But later on I realized I need to do SFTP so I find out Winscp. But the script has to be changed.
The change is primarily:
...shell(...winscp.com /script=script.txt)
and open user:password@sftp.com is also structurally different from my previous script.
Now it is working on my side and I need to do test with SFTP account of real customers.
