Editor in 3.1.7 changes files from unix format to dos format
thedobc
Editor in 3.1.7 changes edited files from unix LF's to dos CR/LF.
After editing files you have to run dos2unix on them
thedobc
Re: Editor in .1.7 changes files from unix format to dos format
Only if you configure it to do so.
Sorry. I meant 4.1.7
I can't find where this is configured. I looked at every option I can see.
Never mind. I see in the docs;
The internal editor supports only Windows-format text files.
So I guess I will need to configure an external editor. But I don't remember having this problem until recently. I have been using WinSCP since the early 3.xx versions.
You may have changed default transfer mode in WinSCP.
dandv
Same bug in 4.1.8 - editor saves CRLF no matter what
I'm encountering the same bug in 4.1.8. The internal editor will save the newlines in a file as CRLFs, no matter what. This does not involve any transfers. Simply edit a LF-separated file with the built-in editor, then save it. Notice that the linbreaks have been converted to CR/LF.
It does not matter, but I had the end-of-line characters set to "LF" in my Server Environment preferences.
Re: Same bug in 4.1.8 - editor saves CRLF no matter what
What protocol?
Re: SFTP
dandv wrote:
The server protocol is SFTP with "Allow SCP fallback", but no transfer is ever taking place.
Are you editing local files or what?
Re: SFTP
Yes, for example before transferring them.
Would be worth mentioning that initialy.
Well you are editing file on Windows, so WinSCP uses CRLF.
