Replace Space character in Underscore on upload
MarcB
Hi Martin,
First of all: WinSCP is super. Thanks for that.
I am wondering if it is possible to change a space character in a (Windows)filename in an underscore. Spaces in a filename are not always correctly understood by programs in a Unis like environment.
Thanks in advance for your reply.
Marc
Re: Replace Space character in Underscore on upload
WinSCP does not support that. I can add the feature, if more users ask for that... :-)
right now it would be great
rudfaden
Denmark
I would like that feature to
rudfaden wrote:
I copy a lot of files from windows to a linux server. Linux does not like spaces. So i convert all the spaces to underscores.
Why do you think that Linux likes spaces less than Windows?
