Can't see any directories using FTP
checky
Hi!
First of all: I am using WinSCP already for a couple of years and I really like it. Thanks a lot for all the work you've put into this great software.
One thing worries me: I am using FileZilla for FTP usually. Since FileZilla 3 I don't like it too much anymore plus I've recently found out the the vast of the FTP code in WinSCP is from FileZilla anyways. I really like the new feature for the "send to" menu which leaded me to the whish to completely get rid of all other FTP tools but for ONE machine ( a local NAS machine ) FTP refuses to work. So I finally get to the actual problem:
When I connect to my NAS called "Titania" no directories or files are shown. I switched from passive to active and changed settings whereever I could find. Nothing helps. Opera and TotalCommander are showing the directory structure just fine but WinSCP (FileZilla 3.1.0.1 does not work well too) does not show anything.
The only thing I am able to see at the top is "/root" and a little ".." further down in the window where the directories and files should show.
Accessing folders directly works - but still NO files or directories are shown.
My WinSCP version is 4.1.7 (Build 413) which I have downloaded / upgraded today.
The log of what happens:
____________________________________________________________________________________
. 2008-10-27 22:11:59.203 --------------------------------------------------------------------------
. 2008-10-27 22:11:59.203 WinSCP Version 4.1.7 (Build 413) (OS 5.1.2600 Service Pack 2)
. 2008-10-27 22:11:59.203 Login time: Montag, 27. Oktober 2008 22:11:59
. 2008-10-27 22:11:59.203 Session name: checky@TITANIA
. 2008-10-27 22:11:59.203 Host name: TITANIA (Port: 21)
. 2008-10-27 22:11:59.203 User name: checky (Password: Yes, Key file: No)
. 2008-10-27 22:11:59.203 Tunnel: No
. 2008-10-27 22:11:59.203 Transfer Protocol: FTP
. 2008-10-27 22:11:59.203 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2008-10-27 22:11:59.203 Proxy: none
. 2008-10-27 22:11:59.203 FTP: Passive: No
. 2008-10-27 22:11:59.203 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-10-27 22:11:59.203 Cache directory changes: Yes, Permanent: Yes
. 2008-10-27 22:11:59.203 DST mode: 0
. 2008-10-27 22:11:59.406 Verbinde mit TITANIA ...
. 2008-10-27 22:11:59.406 FtpControlSocket.cpp(1056): OnConnect(0) OpMode=1 OpState=-1 caller=0x01e09a0c
. 2008-10-27 22:11:59.421 Verbunden mit TITANIA. erwarte Willkommensnachricht ...
. 2008-10-27 22:12:00.546 FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-1 caller=0x01e09a0c
< 2008-10-27 22:12:00.546 220 titania FTP server ready.
> 2008-10-27 22:12:00.546 USER checky
. 2008-10-27 22:12:00.546 FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=0 caller=0x01e09a0c
< 2008-10-27 22:12:00.546 331 Password required for checky.
> 2008-10-27 22:12:00.546 PASS ********
. 2008-10-27 22:12:00.562 FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=3 caller=0x01e09a0c
< 2008-10-27 22:12:00.562 230 User checky logged in.
> 2008-10-27 22:12:00.562 SYST
. 2008-10-27 22:12:00.562 FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-14 caller=0x01e09a0c
< 2008-10-27 22:12:00.562 215 UNIX Type: L8
> 2008-10-27 22:12:00.562 FEAT
. 2008-10-27 22:12:00.562 FtpControlSocket.cpp(878): OnReceive(0) OpMode=1 OpState=-13 caller=0x01e09a0c
< 2008-10-27 22:12:00.562 500 'FEAT': command not understood.
. 2008-10-27 22:12:00.562 Verbunden
. 2008-10-27 22:12:00.562 FtpControlSocket.cpp(4198): ResetOperation(1) OpMode=1 OpState=-13 caller=0x01e09a0c
. 2008-10-27 22:12:00.562 Got reply 1 to the command 1
. 2008-10-27 22:12:00.562 --------------------------------------------------------------------------
. 2008-10-27 22:12:00.562 Using FTP protocol.
. 2008-10-27 22:12:00.562 Doing startup conversation with host.
. 2008-10-27 22:12:00.562 FtpControlSocket.cpp(1283): FtpCommand(PWD) OpMode=0 OpState=-1 caller=0x01e09a0c
> 2008-10-27 22:12:00.562 PWD
. 2008-10-27 22:12:00.562 FtpControlSocket.cpp(878): OnReceive(0) OpMode=2 OpState=-1 caller=0x01e09a0c
< 2008-10-27 22:12:00.562 257 "/" is current directory.
. 2008-10-27 22:12:00.562 FtpControlSocket.cpp(4198): ResetOperation(1) OpMode=2 OpState=-1 caller=0x01e09a0c
. 2008-10-27 22:12:00.562 Got reply 1 to the command 16
. 2008-10-27 22:12:00.562 Getting current directory name.
. 2008-10-27 22:12:00.562 FtpControlSocket.cpp(1290): List(FALSE,0,"/","",1) OpMode=0 OpState=-1 caller=0x01e09a0c
. 2008-10-27 22:12:00.578 Rufe Verzeichnisinhalt ab...
> 2008-10-27 22:12:00.578 TYPE A
. 2008-10-27 22:12:00.578 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=8 caller=0x01e09a0c
< 2008-10-27 22:12:00.578 200 Type set to A.
. 2008-10-27 22:12:00.578 FtpControlSocket.cpp(1290): List(FALSE,0,"","",0) OpMode=4 OpState=8 caller=0x01e09a0c
> 2008-10-27 22:12:00.578 PORT 192,168,0,126,16,7
. 2008-10-27 22:12:00.578 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=7 caller=0x01e09a0c
< 2008-10-27 22:12:00.578 200 PORT command successful.
. 2008-10-27 22:12:00.578 FtpControlSocket.cpp(1290): List(FALSE,0,"","",0) OpMode=4 OpState=7 caller=0x01e09a0c
. 2008-10-27 22:12:00.578 TransferSocket.cpp(597): SetActive() caller=0x01df92d8
> 2008-10-27 22:12:00.578 LIST -a
. 2008-10-27 22:12:00.578 TransferSocket.cpp(418): OnAccept(0) caller=0x01df92d8
. 2008-10-27 22:12:00.578 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=9 caller=0x01e09a0c
< 2008-10-27 22:12:00.578 150 Opening ASCII mode data connection for 'file list'.
. 2008-10-27 22:12:00.578 FtpControlSocket.cpp(1290): List(FALSE,0,"","",0) OpMode=4 OpState=9 caller=0x01e09a0c
. 2008-10-27 22:12:00.578 TransferSocket.cpp(557): OnClose(0) caller=0x01df92d8
. 2008-10-27 22:12:00.578 TransferSocket.cpp(1179): Close() caller=0x01df92d8
. 2008-10-27 22:12:00.578 FtpControlSocket.cpp(2084): TransferEnd(4) OpMode=4 OpState=10 caller=0x01e09a0c
. 2008-10-27 22:12:00.578 FtpControlSocket.cpp(1290): List(TRUE,0,"","",0) OpMode=4 OpState=10 caller=0x01e09a0c
. 2008-10-27 22:12:00.578 .
. 2008-10-27 22:12:00.578 ..
. 2008-10-27 22:12:00.578 ftpd
. 2008-10-27 22:12:00.578 Share
. 2008-10-27 22:12:00.578 WEB
. 2008-10-27 22:12:00.578 mDNSResponder
. 2008-10-27 22:12:00.578 mldonkey.tgz
. 2008-10-27 22:12:00.578 mlnet
. 2008-10-27 22:12:00.578 mt-daapd
. 2008-10-27 22:12:00.578 useradd
. 2008-10-27 22:12:00.578 ushare
. 2008-10-27 22:12:00.578 wget
. 2008-10-27 22:12:00.578 SOFTWARE
. 2008-10-27 22:12:00.578 INSTALL
. 2008-10-27 22:12:00.578 DOKUS
. 2008-10-27 22:12:00.578 myfiles
. 2008-10-27 22:12:00.578 chlog
. 2008-10-27 22:12:00.578 PHOTOS
. 2008-10-27 22:12:00.578 GAMES
. 2008-10-27 22:12:00.578 UPLOAD
. 2008-10-27 22:12:00.578 BACKUP
. 2008-10-27 22:12:00.578 varlibnfs.tar
. 2008-10-27 22:12:00.578 unfsd
. 2008-10-27 22:12:00.578 portmap
. 2008-10-27 22:12:00.578 exports
. 2008-10-27 22:12:00.578 telnetd
. 2008-10-27 22:12:00.578 watch_prog.old
. 2008-10-27 22:12:00.578 message_0.txt
. 2008-10-27 22:12:00.578 DIV
. 2008-10-27 22:12:00.578 TransferSocket.cpp(108): ~CTransferSocket() caller=0x01df92d8
. 2008-10-27 22:12:00.750 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=10 caller=0x01e09a0c
< 2008-10-27 22:12:00.750 226 Transfer complete.
. 2008-10-27 22:12:00.750 FtpControlSocket.cpp(1290): List(FALSE,0,"","",0) OpMode=4 OpState=10 caller=0x01e09a0c
. 2008-10-27 22:12:00.750 Verzeichnisinhalt erfolgreich abgerufen
. 2008-10-27 22:12:00.750 FtpControlSocket.cpp(4198): ResetOperation(1) OpMode=4 OpState=10 caller=0x01e09a0c
. 2008-10-27 22:12:00.765 Got reply 1 to the command 2
. 2008-10-27 22:12:00.765 Startup conversation with host finished.
. 2008-10-27 22:12:02.296 Session upkeep
. 2008-10-27 22:12:02.734 Session upkeep
. 2008-10-27 22:12:03.296 Session upkeep
. 2008-10-27 22:12:03.734 Session upkeep
. 2008-10-27 22:12:04.234 Session upkeep
. 2008-10-27 22:12:04.734 Session upkeep
. 2008-10-27 22:12:05.343 Session upkeep
. 2008-10-27 22:12:05.750 Session upkeep
. 2008-10-27 22:12:06.234 Session upkeep
. 2008-10-27 22:12:06.734 Session upkeep
. 2008-10-27 22:12:07.234 Session upkeep
. 2008-10-27 22:12:07.734 Session upkeep
. 2008-10-27 22:12:08.343 Session upkeep
. 2008-10-27 22:12:08.781 Session upkeep
. 2008-10-27 22:12:09.234 Session upkeep
. 2008-10-27 22:12:09.734 Session upkeep
. 2008-10-27 22:12:10.234 Session upkeep
. 2008-10-27 22:12:10.328 Cached directory change via ".." to "/".
. 2008-10-27 22:12:10.328 Getting current directory name.
. 2008-10-27 22:12:10.359 Directory content loaded from cache.
. 2008-10-27 22:12:10.734 Session upkeep
. 2008-10-27 22:12:11.234 Session upkeep
. 2008-10-27 22:12:11.781 Session upkeep
. 2008-10-27 22:12:12.234 Session upkeep
. 2008-10-27 22:12:12.578 Getting current directory name.
. 2008-10-27 22:12:12.578 FtpControlSocket.cpp(1290): List(FALSE,0,"/","",1) OpMode=0 OpState=-1 caller=0x01e09a0c
. 2008-10-27 22:12:12.578 Rufe Verzeichnisinhalt ab...
> 2008-10-27 22:12:12.578 TYPE A
. 2008-10-27 22:12:12.578 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=8 caller=0x01e09a0c
< 2008-10-27 22:12:12.578 200 Type set to A.
. 2008-10-27 22:12:12.578 FtpControlSocket.cpp(1290): List(FALSE,0,"","",0) OpMode=4 OpState=8 caller=0x01e09a0c
> 2008-10-27 22:12:12.578 PORT 192,168,0,126,16,8
. 2008-10-27 22:12:12.578 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=7 caller=0x01e09a0c
< 2008-10-27 22:12:12.578 200 PORT command successful.
. 2008-10-27 22:12:12.578 FtpControlSocket.cpp(1290): List(FALSE,0,"","",0) OpMode=4 OpState=7 caller=0x01e09a0c
. 2008-10-27 22:12:12.578 TransferSocket.cpp(597): SetActive() caller=0x01e26b0c
> 2008-10-27 22:12:12.578 LIST -a
. 2008-10-27 22:12:12.578 TransferSocket.cpp(418): OnAccept(0) caller=0x01e26b0c
. 2008-10-27 22:12:12.578 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=9 caller=0x01e09a0c
< 2008-10-27 22:12:12.578 150 Opening ASCII mode data connection for 'file list'.
. 2008-10-27 22:12:12.578 FtpControlSocket.cpp(1290): List(FALSE,0,"","",0) OpMode=4 OpState=9 caller=0x01e09a0c
. 2008-10-27 22:12:12.578 TransferSocket.cpp(557): OnClose(0) caller=0x01e26b0c
. 2008-10-27 22:12:12.578 TransferSocket.cpp(1179): Close() caller=0x01e26b0c
. 2008-10-27 22:12:12.578 FtpControlSocket.cpp(2084): TransferEnd(4) OpMode=4 OpState=10 caller=0x01e09a0c
. 2008-10-27 22:12:12.578 FtpControlSocket.cpp(1290): List(TRUE,0,"","",0) OpMode=4 OpState=10 caller=0x01e09a0c
. 2008-10-27 22:12:12.578 .
. 2008-10-27 22:12:12.578 ..
. 2008-10-27 22:12:12.578 ftpd
. 2008-10-27 22:12:12.578 Share
. 2008-10-27 22:12:12.578 WEB
. 2008-10-27 22:12:12.578 mDNSResponder
. 2008-10-27 22:12:12.578 mldonkey.tgz
. 2008-10-27 22:12:12.578 mlnet
. 2008-10-27 22:12:12.578 mt-daapd
. 2008-10-27 22:12:12.578 useradd
. 2008-10-27 22:12:12.578 ushare
. 2008-10-27 22:12:12.578 wget
. 2008-10-27 22:12:12.578 SOFTWARE
. 2008-10-27 22:12:12.578 INSTALL
. 2008-10-27 22:12:12.578 DOKUS
. 2008-10-27 22:12:12.578 myfiles
. 2008-10-27 22:12:12.578 chlog
. 2008-10-27 22:12:12.578 PHOTOS
. 2008-10-27 22:12:12.593 GAMES
. 2008-10-27 22:12:12.593 UPLOAD
. 2008-10-27 22:12:12.593 BACKUP
. 2008-10-27 22:12:12.593 varlibnfs.tar
. 2008-10-27 22:12:12.593 unfsd
. 2008-10-27 22:12:12.593 portmap
. 2008-10-27 22:12:12.593 exports
. 2008-10-27 22:12:12.593 telnetd
. 2008-10-27 22:12:12.593 watch_prog.old
. 2008-10-27 22:12:12.593 message_0.txt
. 2008-10-27 22:12:12.593 DIV
. 2008-10-27 22:12:12.593 TransferSocket.cpp(108): ~CTransferSocket() caller=0x01e26b0c
. 2008-10-27 22:12:12.593 TransferSocket.cpp(1179): Close() caller=0x01e26b0c
. 2008-10-27 22:12:12.718 FtpControlSocket.cpp(878): OnReceive(0) OpMode=4 OpState=10 caller=0x01e09a0c
< 2008-10-27 22:12:12.718 226 Transfer complete.
. 2008-10-27 22:12:12.718 FtpControlSocket.cpp(1290): List(FALSE,0,"","",0) OpMode=4 OpState=10 caller=0x01e09a0c
. 2008-10-27 22:12:12.718 Verzeichnisinhalt erfolgreich abgerufen
. 2008-10-27 22:12:12.718 FtpControlSocket.cpp(4198): ResetOperation(1) OpMode=4 OpState=10 caller=0x01e09a0c
. 2008-10-27 22:12:12.718 Got reply 1 to the command 2
. 2008-10-27 22:12:12.750 Session upkeep
I really hope to get a good tip or this can be fixed.
If any further information or testing is needed I am more than happy to help with the investigation.
Thanks a lot for reading!
checky
checky
I needed to delete 2 entries about directories on the drive that are hitting the spam filter in this forum :-)
cheers!
Re: Can't see any directories using FTP
Can you provide me your email address, so I can send you a debug version of WinSCP to track the problem? If you do not want to post the address here, you can send me an email. You will find it (if you log in) in my forum profile. Please include link to this topic. Thanks.
checky
Yea that's fine with me.
Mail me at <email removed> (and if possible just delete this addy from this post).
Thanks a lot!
