Vista 64bit and WinSCP login Window -- buttons dissappear
Taimar
It happens, when the login window is open and I press Alt-key on my keyboard.
Example:
Re: Vista 64bit and WinSCP login Window -- buttons dissappear
Thanks for your post. This issue has been added to tracker.
Does this happen with other dialogs as well?
Yes.
<invalid hyperlink removed by admin> (<invalid hyperlink removed by admin>) <invalid hyperlink removed by admin> (<invalid hyperlink removed by admin>) <invalid hyperlink removed by admin> (<invalid hyperlink removed by admin>)
Holodyn
Confirm This
I'm on Vista 32 and this happens as well on all dialogs - on initial load of first WinSCP instance the buttons appear. After the initial instance loads then the problem begins and persists for all additional instances of WinSCP loaded until all are shut down.
Re: Confirm This
Can others confirm that it happens for second and further instances only?
Taimar
Re: Confirm This
No, it happens also in first instance.
And it's not fixed in WinSCP 4.2.1 beta.
Using 64bit Vista.
