Version 417 often fails on my server.
PMunn
USA
I recently upgraded from 407 to 417 and find that 417 frequently fails when run by the scheduler on the Win 2000 server. It's running a script and doesn't generate any output log when it fails. When run interactively it often does work, but not always.
I've reverted back to 407 for now.
I went to look for 416 and test that but it doesn't seem to work.
If anyone has any advice on getting more detailed information out of it to help troubleshoot I'm all ears.
Re: Version 417 often fails on my server.
What is output log? Does it generate a session log?
What does it do then?
What protocol are you using?
PMunn
USA
results
The command includes a switch to write out a detailed transfer log. It doesn't write one out, so I can't see what the problem was. Maybe that's what you call a session log.
It runs the command but doesn't output any failure message. It also doesn't send the file to the server as required.
It's using SFTP.
Re: Bug started in version...
OK thanks. Can you try to combine winscp.com from 4.1.6 and winscp.exe from 4.1.7 (and vice versa) to see if the bug is caused by the .com or the .exe? Thanks!
PMunn
USA
solved: permissions problem
Hi Martin,
I tried the debug version and it led me to figure out that it was a permissions setting on the EXE. There's no bug in the Winscp 417 version after all, it just wasn't set properly to run. Previously I hadn't needed to modify the settings on the other EXEs so I didn't think to change them for this one either.
Thanks for your help!
