Wrong Icon Size in Properties
wai
In Windows XP, when using Large icons size for program (Taskbar and Start Menu Properties -> Customize -> General), click the "Properties" on the ftp panel's file, the icon on the top left is too big, with some cropped.
Re: Wrong Icon Size in Properties
I'm not able to reproduce that. Are you sure that if you enable small icons the problem goes away? Can you post a screenshot?
wai
sorry should be
Display Properties > Effects > Use large icons
screenshot here:
