custom command : tar for folders?
The new custom command menu is great!
But I have a problem =)
I wrote this to quickly compresse files and folders.
tar -zcf "!".tgz "!"
It does not work for folders. I right clicked on a folder to apply this compress command and winscp tried to compress every file inside the folder, not the folder itself..
Unsupported feature or did I do something wrong?
Olivier
Re: custom command : tar for folders?
Well, I understand. Problem is that sometimes you need a custom command to traverse thru subdirectories, sometimes to apply to folders. I'll try to find some solution.
