Moving files within one server
Splinty
Russia, Kurgan
Hi guys!
I'm really glad to look at UTF-8 support. It makes me almost happy :lol:
But would You clarify is it possible to move files on remote server without downloading it locally? I suspect that it's possiple only while using SCP... that doesn't support UTF-8...
Splinty
Oh well, thank You, but my question to be more correct, concerns FAR plugin, sorry.
As i understand plugin doesn't have such features like GUI application, right?
_________________
Sors mea Jesus!
Splinty
Russia, Kurgan
I've found, that WinSCP itself is much more interesting for me and solve almost any my task. I do appreciate You for Your work!
By the way i found a bug while intense moving directories by means of dragNdrop.
I turned on a tree and moving directories from one to another and almost every 5-6 moves non critical error appears <invalid hyperlink removed by admin>
I move "Third day" from ./musfull/5 to ./musfull/f
In fact everything are moved as ordered but it's something wrong with automatic tree repainting.
After pressing OK on error dialog tree shows old "Third day" <invalid hyperlink removed by admin> on old place (in fact absent) and new "Third day" on new place (in fact present and just moved)
So you drag the directory from the tree into another place on the same tree, correct?
