(ERROR)ls -la --full-time
Lucholp
El comando 'ls -la --full-time'
ha fallado. Ha devuelto el código de error 1 y ls: unrecognized option `--full-time'
BusyBox v1.2.1 (2008.04.29-16:34+0000) multi-call binary
Usage: ls [-1AacCdeFilnpLRrSsTtuvwxXhk] [filenames...]
como mensaje de error.
ROCKYS08
QUESTION
HI !!!
1) How I check if a file to be transferred already was sent ?
2) How I check if file is shipping and get everything ?
3) How can I send a message to the ftp server ?
Thanks !!!
ROCKYS08
Script
This is my script !!!
@echo off
"C:\SICAES\BACKUP\DLL\WinSCP\WinSCP.com" ^
  /log="C:\SICAES\BACKUP\DLL\WinSCP\WinSCP.log" /ini=nul ^
  /command ^
     "open ftp://SEVE:SEVE@seve.ddns.net/"%1"/" ^
      "put D:\SICAESDB\BACKUP\DATOS\"%2 ^
     "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
 exit /b %WINSCP_RESULT%
PLEASE ... HELP ME !!!
Where and as locate those commands ... ls -la ... etc and ERROR and MSG ???
THANKS !!!
Re: QUESTION
It's sent when the put command finishes or when a whole script finishes.
What does it mean "file is shipping"?
What message?
ROCKYS08
QUESTION
It's sent when the put command finishes or when a whole script finishes. ... BOTH CASES
Quote:
2) How I check if file is shipping and get everything ? ... Transferred or Send
What message? ... I end the process good
thanks
Re: QUESTION
That was not a question. That was a statement. A transfer is complete once the put command finishes. What do you want to check?
Sorry, can you be more specific? What's the difference between 1) and 2)?
Again, this is quite vague. There's no way to send a "message" to an FTP server. If the FTP server expects some kind of indication about completed transfer, it has to have it's specific and defined way to do so. We cannot know that. Ask your server administrator.
You may want to read https://winscp.net/eng/docs/script_locking_files_while_uploading
