WinSCP - Windows Vista compatibility
I would like to know if WinSCP v4.0.7 and v3.8.2 are compatible with 32-bit and 64-bit Windows Vista.
What are the latest and earliest compatible versions?
Thanks.
Re: WinSCP - Windows Vista compatibility
WinSCP does work on Vista. There were minor issues in the past. Generally you should always use the latest version.
