custom commands input and remote move command
mattgick
Hi! I just have to say it again, Great Program!!! Keep up the good work!
My request:
1: a "move remotely" command, enabling the user to move a set of files/dirs to one other remote dir without having to download it first ;)
2: the custom commands now recieve a ! for the filename/dir... how about a %1 or something for a custom arguement. This would make my first request useless ;) since you could do: "mv ! %1" for moving a lot of files/dirs to one other directory.
Thanks!
mattgick
while I'm at it ;)
How about adding shotcut keys to the custom commands? so you can quickly call alt+1 alt+2 to do different things?
Re: custom commands input and remote move command
Good idea, I've thought about it already too. Next release :-)
mattgick
Re: while I'm at it ;)
sorry about that, alt+# seems to be in use by session cycling... maybe some other shortcut?
Maybe... :-)
cool, thanks for the quick response by the way :D
I support this. Remote copy would be quite nice feature.
Next version will support at least the point 2 proposed by mattgick, which would allow remove move with SCP (not SFTP).
