List index out of bounds (-1) error (v. 4.1.6)
JK
I noticed that this was a bug error message in an older version (this is my first time using WinSCP), and it was apparently fixed then. However, I'm receiving this when I attempt to log in to my FTP (standard, not SFTP).
Actually, I was able to log in last night without issues, but no longer. Additionally, I am still able to log in with other software, so I don't think it's a server problem.
It occurs while attempting "Reading directory listing..."
Is there any information I can give you to help with this?
JK
Fresh installation
I just wanted to say that I unintalled WinSCP, downloaded it again, and gave it a fresh install. It is working again like it did last time after initially being installed. If the errors pop up again I'll make a note here.
Thanks for the program. I'm really looking forward to using it!
enriq766
Same Error
I am trying to issue a chown command and getting "List index out of bounds (-1)" also
I am trying to simply change the owner of a file on my server.
enriq766@gmail.com thanks!
Re: Same Error
Thanks for your post. This bug is being tracked already.
