BUG: WinSCP deletes files on remote FTP server itself
artem
USA
WinSCP 4.0.6 (build 358) deletes files on remote FTP server when user selects "Move" but halts download.
After that on user's machine there is only part of the file and it is deleted on remote FTP.
Very tough bug. I loosed couple of my files this way :((
sh100
What can I do if this bug is fixed but I still get errors
I have WinSCP 4.1.6 (Build 412). I have same issue as discribed above, files on remote server gets deleted if I gave save command and connection got disconnected.
In forum it says bug is been fixed so do I need to do anything? download anything/ change any settings to not get this problem with connection.
Re: What can I do if this bug is fixed but I still get errors
Please post a log file showing the problem.
mro
winscp IS STILL DELETING FILES BY ITSELF
winscp DELETED my files BY ITSELF!. I was only logged in, no single operation was performed and he deleted files from my ftp! Destroying almost entire database! Vesrion 4.3.1 (Build 1099)Today winscp did it 3 times on 2 different pc`c
Re: winscp IS STILL DELETING FILES BY ITSELF
Have you any logs proving that?
modmani
Winscp deleting files on remote server when connection lost
It happened to me too :( Unfortunately the user does not have any log
the version of winscp is 4.2.9
Also I was not able to reproduce the error.
Can you let me know how can I check the logs of winscp
