FTP proxy
FTP proxy
Could you please add support for ftp proxies for ftp transfers? I need support because if I try to use our HTTP proxy I got "No valid HTTP reponse"...
Thank you in advance
Tim
P.S.: WinSCP is great!
NvdPDutchie
HTTP proxy / user with no logon
i don't know if this is the same request, but I would appreciate it if this feature could be added.
Re: HTTP proxy / user with no logon
I do not understand. WinSCP supports HTTP proxy. What do you miss?
NvdPDutchie
Hi rikryl, for remote ftpsites we connect through our proxy. In our proxy no users are defined. In Winscp you have to give up an user and pswd and that doesn't work in our case. So need the choice user with no logon.
So just do not fill the boxes...
kbuff
I'm trying to use WinSCP to connect to an FTP site that requires a username/password combination, and can't make it work, whereas core ftp LE client (v2.1, build 1549) works fine. I'm connecting through a frox/squid proxy running on FreeBSD.
Kurt
Any error message? Can you post a log file both from WinSCP and CoreFTP?
yahnice
Hi, i have the same problem to .
Here are errors messages and log file : (sorry for the french, but i can't have messages in english)
Connexion au serveur proxy impossible
Une tentative d'accès à un socket de manière interdite par ses autorisations d'accès a été tentée.
La connexion a échouée.
. 2009-02-13 12:24:10.136 --------------------------------------------------------------------------
. 2009-02-13 12:24:10.137 WinSCP Version 4.1.8 (Build 415) (OS 6.0.6001 Service Pack 1)
. 2009-02-13 12:24:10.137 Login time: vendredi 13 février  2009 12:24:10
. 2009-02-13 12:24:10.137 --------------------------------------------------------------------------
. 2009-02-13 12:24:10.137 Session name: XXXX@xxx.xxx.com
. 2009-02-13 12:24:10.137 Host name: ftp://xxx.xxx.com (Port: 21)
. 2009-02-13 12:24:10.137 User name: xxxxxx (Password: Yes, Key file: No)
. 2009-02-13 12:24:10.137 Tunnel: No
. 2009-02-13 12:24:10.137 Transfer Protocol: FTP
. 2009-02-13 12:24:10.137 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-02-13 12:24:10.137 Proxy: HTTP
. 2009-02-13 12:24:10.138 HostName: 192.168.40.25 (Port: 3128); Username: ; Passwd: No
. 2009-02-13 12:24:10.138 FTP: Passive: Yes
. 2009-02-13 12:24:10.138 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-02-13 12:24:10.138 Cache directory changes: Yes, Permanent: No
. 2009-02-13 12:24:10.138 DST mode: 1
. 2009-02-13 12:24:10.138 --------------------------------------------------------------------------
. 2009-02-13 12:24:10.216 Connexion à ftp://xxx.xxx.com...
. 2009-02-13 12:24:10.216 ControlSocket.cpp(214): m_pProxyLayer changed state from 0 to 1   caller=0x02ebbe44
. 2009-02-13 12:24:10.216 ControlSocket.cpp(214): m_pProxyLayer changed state from 1 to 2   caller=0x02ebbe44
. 2009-02-13 12:24:10.217 ControlSocket.cpp(214): m_pProxyLayer changed state from 2 to 6   caller=0x02ebbe44
. 2009-02-13 12:24:10.217 Connexion au serveur proxy impossible
. 2009-02-13 12:24:10.217 FtpControlSocket.cpp(1056): OnConnect(10013)  OpMode=1 OpState=-1   caller=0x02ebbe44
. 2009-02-13 12:24:10.217 Une tentative d'accès à un socket de manière interdite par ses autorisations d'accès a été tentée.
. 2009-02-13 12:24:10.217 FtpControlSocket.cpp(1213): DoClose(0)  OpMode=1 OpState=-1   caller=0x02ebbe44
. 2009-02-13 12:24:10.217 FtpControlSocket.cpp(4198): ResetOperation(4100)  OpMode=1 OpState=-1   caller=0x02ebbe44
. 2009-02-13 12:24:10.217 La connexion a échouée.
. 2009-02-13 12:24:10.217 Got reply 1004 to the command 1
* 2009-02-13 12:24:10.267 (ESshFatal) La connexion a échouée.
* 2009-02-13 12:24:10.267 Connexion au serveur proxy impossible
* 2009-02-13 12:24:10.267 Une tentative d'accès à un socket de manière interdite par ses autorisations d'accès a été tentée.
* 2009-02-13 12:24:10.267 La connexion a échouée.
. 2009-02-13 12:24:29.360 FtpControlSocket.cpp(181): ~CFtpControlSocket()   caller=0x02ebbe44
. 2009-02-13 12:24:29.360 FtpControlSocket.cpp(1213): DoClose(0)  OpMode=0 OpState=-1   caller=0x02ebbe44
. 2009-02-13 12:24:29.361 FtpControlSocket.cpp(4198): ResetOperation(4100)  OpMode=0 OpState=-1   caller=0x02ebbe44
. 2009-02-13 12:24:29.361 ControlSocket.cpp(89): ~CControlSocket()   caller=0x02ebbe44
yahnice
I believe that yout problem is unrelated to the topic. The topic is about FTP proxy. You are using HTTP proxy.
It seems that your proxy requires authentication and you have not specified any username/password.
Arjan van Rees
The problem is you can't choose a FTP proxy for normal FTP connections. You can select FTP proxy for SFTP connections. We need the ability to choose a FTP proxy for standard FTP.
You cannot specify FTP proxy for SFTP connection.
BTW, FTP proxy request is being tracked already.
