Update of registry key ProxyPasswordEnc
Hi
Is it possible to update the registry key ProxyPasswordEnc with a script ?
I have many sessions and have to change proxy password each month. Using the GUI take to long time. With a script I can call the utility for each session with the new password as an argument.
Regards Michael
Re: Update of registry key ProxyPasswordEnc
Sure. Just export the registry. Use your script on the exported file. And import it back. Or use INI file instead of the registry.
The data in registry key ProxyPasswordEnc is enkrypted so how can I just update it without encrypt it first ?
Regards Michael
Sorry, I've misunderstood the question. You can use ProxyPassword instead, which in not encrypted.
