Passphrase questioning when using internal editor
derDepp
Hey,
I have the following problem:
When I open a file (e.g. bla.php) on my server (I'm using public key authentication with a passphrase) and I save the file, I'm being prompted for the passphrase, but only when saving for the first time. Is it possible to now ask for the passphrase again?
Thanks!
Re: Passphrase questioning when using internal editor
WinSCP uses background transfer for uploads from editor. Once it opens the background session for the first upload, it keeps it open for future uploads. So no it is not possible.
derDepp
OK thanks so far. Wouldn't it be possible to directly open the background session on start of the normal session with the entered passphrase?
First you wanted to ask for passphrase every time. Now you want to avoid asking. So what your purpose?
