How to trap output running linemode
madams
San Jose, CA. USA
Running WinSCP416 on Windows XP
Just wondering if anyone knows how to redirect the output when running winscp in line mode using /script
Since it spawns a second dos window the normal redirect syntax does not work.
I'm running the standalone executable "winscp416.exe".
Everything works great, I just need to append to a logfile for reference. The /log option has way do much detail.
Thanks for any help!!!!
Mike
madams
San Jose, CA. USA
Will that work with the standalone executable(winscp416.exe)
Will that work with the standalone executable(winscp416.exe)? Do I need to do a standard installation on another computer to get the winscp.com and copy it to the same directory as the winscp416.exe? Does that then know to call winscp416.exe?
Thanks,
Mike
Re: Will that work with the standalone executable(winscp416.exe)
Yes you need to get the .com from installation. You have to match names of the .com and the .exe in either way.
