Sync detecting changes but not uploading...
Theaxiom
I have WinSCP running, it is detecting changes but it is not uploading the changed files. However if I create a file locally, it will upload it, and if I delete it, it will delete it from the remote machine. What am I doing wrong?
I am using the most recent version available from the main download link on Windows Vista Ultimate x64, I even tried running as Administrator to see if that made a difference, and it does not.
Thanks in advance for your help.
Travis
Re: Sync detecting changes but not uploading...
WinSCP probably sees the remote timestamp of older file as newer that local timestamp. First make sure, WinSCP understands remote timestamps correctly.
