Two problems: hanging uploads and multiple file select
JHSachs
I'm running WinSCP version 4.0.7 under Windows XP. I've recently started having problems with flaky connects. Typically the first time I try to upload a file after I connect, the upload approaches the end of the file and then hangs. I get a timeout and lost connection, and am left with a zero-length file on the host. Then I reconnect and repeat the upload, and it works perfectly.
I've also had problems selecting multiple files on the local system (but not the host) with control-click and shift-click. Sometimes these operations work normally. Other times, when I hold down the control or shift key and click, the program displays a broken line around the file I clicked on, and the previous selections (if any) are not changed.
Any ideas what is happening? I love the program otherwise, but these two problems are making it very difficult to use.
JRB_BMB
Midlands, UK
Try upgrading to the latest version 4.1.5 and re-test. If the problems still arise then post log files etc to help with a diagnosis.
Also let us know, what protocol are you using.
Re: Two problems: hanging uploads and multiple file select
Are you able to reproduce that or does it happen randomly?
JHSachs
Absolutely reproducible since it started. I'll install the new version and report back.
JHSachs
I tried version 4.1.6 (with a different host) and got the same problem.
Please tell me where to find the log files. There's nothing that looks like one in the WinSCP directory, or in its only subdirectory, PuTTY.
With both hosts, the protocol is FTP.
JHSachs
PRELIMINARY
257 "/httpdocs" is current directory.
Retrieving directory listing...
TYPE A
200 Type set to A.
PORT 192,168,1,64,14,155
200 PORT command successful.
LIST -a
150 Opening ASCII mode data connection for /bin/ls.
226 Transfer complete.
Directory listing successful
Changing directory to "pix".
CWD pix
250 CWD command successful.
Getting current directory name.
PWD
257 "/httpdocs/pix" is current directory.
TYPE A
200 Type set to A.
PORT 192,168,1,64,14,157
LIST -a
REST 0
350 Restarting at 0.
FIRST ATTEMPT TO UPLOAD A FILE
Copying 1 files/directories to remote directory "/httpdocs/pix/"
PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
TM: M; ClAr: No; CPS: 0; ExclM(No):
AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
File: "C:\Documents and Settings\Jonathan Sachs\My Documents\NatLinkInstallLog.txt"
Copying "C:\Documents and Settings\Jonathan Sachs\My Documents\NatLinkInstallLog.txt" to remote directory started.
Ascii transfer mode selected.
Starting upload of C:\Documents and Settings\Jonathan Sachs\My Documents\NatLinkInstallLog.txt
TYPE A
200 Type set to A.
PORT 192,168,1,64,14,159
STOR NatLinkInstallLog.txt
150 Opening ASCII mode data connection for NatLinkInstallLog.txt.
Timeout detected.
TYPE A
200 Type set to A.
IT SITS SHOWING 0% TRANSFERRED UNTIL A TIMEOUT OCCURS
Timeout detected.
Connection was lost, asking what to do.
Asking user:
Lost connection. ("Timeout detected.","Copying files to remote side failed.","Opening ASCII mode data connection for NatLinkInstallLog.txt.")
Asking user:
Connecting to jhsachs.com ...
Connected with jhsachs.com. Waiting for welcome message...
220 Microsoft FTP Service
USER jsachs
331 Password required for jsachs.
PASS *******
230 User jsachs logged in.
SYST
215 Windows_NT
FEAT
211-FEAT
SIZE
MDTM
211 END
Connected
Doing startup conversation with host.
Changing directory to "/httpdocs/pix".
Synchronizing current directory "/httpdocs/pix".
CWD /httpdocs/pix
CWD /httpdocs/pix
PWD
Startup conversation with host finished.
TYPE A
200 Type set to A.
PORT 192,168,1,64,14,164
LIST -a
TYPE A
200 Type set to A.
PORT 192,168,1,64,14,166
APPE NatLinkInstallLog.txt
Upload successful
TYPE A
200 Type set to A.
PORT 192,168,1,64,14,168
LIST -a
