Keepuptodate in console: inaccurate progress indication
drmrbrewer
UK
I'm happily using keepuptodate invoked in a console window. It works fine in substance, no problems. The only thing is the text indication of upload progress: can't really rely on it. I just did a test on a small image, for example... the % indication on the end of the line went up as the file was copied, but ended up on 71%. The image was copied fine, it's just the % indication (and the data amount copied is also less than it really is). On a very small text file, the % amount finished on 0% and the data amount finished on 0, despite the file being copied. BTW the image was 45 KB in size.
Thanks,
Mike
Re: Keepuptodate in console: inaccurate progress indication
I wasn't able to reproduce that.
What version of WinSCP are you using? What protocol? Do you use winscp.exe or winscp.com?
