window title: add servername in front
FredJ
Currently a winscp window title looks like this:
"/path/path/path/path - account@servername - WinSCP"
Would be cool, to have the window title like this:
"servername - /path/path/path/path - account@server - WinSCP"
Reason for request:
In the windows task bar you can see the first ~10 characters of a window title. If you have several winscp windows open, it's sometimes difficult to select the correct window in the task bar.
Usually the first 10 letters of a servers path do not help distinguishing several open winscp sessions.
JRAN1
Custom Window Title with Command Line Util
I would like to customize the Window Title when I use WinSCP via command line. I have numerous scripts running on the same machine. When a window gets left behind, it's difficult to determine which script needs editing. Thanks, James
Re: Custom Window Title with Command Line Util
You can setup a specific stored session for each of your script.
Custom window title
Still it would be nice to specify title on the command line. I have lots of hosts accessed via on demand generated SSH tunnels. It will show me user@localhost - not the name of the server.
Re: Custom window title
OK, this request is tracked here:
https://winscp.net/tracker/1183
