winscpt and ssis task
mr4100
Hi, I can't seem to figure out the command line syntax to run this software with SSIS execute process task.
Here is what I have so far.
I call the WinScp.exe
I pass this line in as my argument
user@mysite.com /privatekey/ "\\test\f$\Import\scp Keys\OSF priv key.ppk"/script="\\sqltest\e$\SSIStest\Export\sftpscript.txt"
it times out everytime?
Re: winscpt and ssis task
Maybe like this:
user@mysite.com /privatekey="\\test\f$\Import\scp Keys\OSF priv key.ppk" /script="\\sqltest\e$\SSIStest\Export\sftpscript.txt"
user@mysite.com /privatekey/ "\\test\f$\Import\scp Keys\OSF priv key.ppk"/script="\\test\a$\SSIStest\Export\sftpscript.txt"
got it!
joney
SSIS Execute Process Task not working
I have the following script that I wrote to a text file called download.txt:
option batch on
# Disable overwrite confirmations
# Do the work
get file*.zip c:\Folder
# Close and exit
close
I am using an SSIS Execute Process Task with the following settings:
RequireFullFileName: True
Executable: C:\Program Files\WinSCP\WinSCP.exe
Arguments: user@ftp.server.com:2222 /privatekey="c:\Folder\PKey.ppk" /script="c:\Folder\download.txt"
WorkingDirectory: c:\Folder
The rest of the settings are default.
When I execute the task, I receive an [Execute Process Task]Progress: Operation Complete - 100 percent complete. However it did not transfer (get) the zip file from the FTP server. What am I doing wrong?
HoMi
Re: SSIS Execute Process Task not working
option batch on
# Do the work
# Close and exit
close
I have the same problem :(
When I'm running the command with scriptfile as agrument at the commandshell I get no errormessage, but it downloads nothing :(
Use /log to enable logging in WinSCP and inspect the log file.
JRB_BMB
Midlands, UK
Change your arguments from using /script or /key to -script and -key
And call winSCP.COM not the EXE.
Also try to save the connection in winSCP and then open the connection in the script. If you're using a secure server then there shouldn't be an issue with this in terms of security.
I do not think this makes any difference.
JRB_BMB
Midlands, UK
Well at least this way is tried and tested; so eitherway they can try both and if it doesn't work with '/' then it's an easy change.
I don't know if you have any SSIS experience Martin but it's not exactly a nice experience using it! :P
trinath89
NOIDA
Passing parameters to winscp from ssis execute process task
now i know how to send the script file location as an argument
please tell me how to send the parameter with it
-script=D:\script.txt -parameter c:\database\templete.xls
and in the script
option batch off
open XXXXXXXXXXXX
put %1% /database/
will the above code work?
Thanks and Regards
Trinath
Re: Passing parameters to winscp from ssis execute process task
and in the script
option batch off
open XXXXXXXXXXXX
put %1% /database/
The official syntax is to use slashes:
Though dashes do too.
To make it perfect prepend the parameters with //
/script=D:\script.txt /parameter c:\database\templete.xls
https://winscp.net/eng/docs/commandline#two_slashes
Also you should better enclose the %1% in double quotes:
put "%1%" /database/
https://winscp.net/eng/docs/scripting#syntax
nik27184
SSIS WinSCP integration using Ppk without Password
--file upload
1) Use Execute Process Task in SSIS
2) in Process - Executable call WinSCP.COM (example : C:\SOFTWARES\WinSCP\WinSCP.com)
3) in Arguments called this
-script="E:\SOFTWARES\WinSCP\TEST_Upload.txt" /log=C:\temp\WinSCP_log.txt
--TEST_Upload file below
open UserName@FTPsiteName -privatekey="ppk file path (example : C:\test\Private.ppk")
lcd C:\TEST\
mput *.txt
close
Thank you !
Nik.
