Error Code: 24 - Specified File is a Directory
bkrontz
NYC
Hi All!
I'm getting the following error using WinSCP Portable 4.1.5 when trying to upload using SSH to my Serv-U 7.2.0.0 Server(Beta).
Cannot change properties of file '/D:/FTP/Username/Foldername/SubFoldername/'.
The specifed file was a directory in a context where a directory cannot be used.
Error code: 24
Error message from server (en): Specified file is a directory.
Request code: 9
The problem started when I stopped the copy of Foldername earlier. Any further copy of that directory by dragging the folder from one side of the Commander GUI to the other resulted in this popping up. It does ask if I want to overwrite to which I reply "Newer Only." After I tell it to overwrite with newer files only, it may copy a few things and then fail... or fail right away. WinSCP also behaves the same way if I choose to overwrite everything.
Being that it worked before, I deleted the Foldername directory to start from scratch. The error now pops up immediately. The only operation performed was the creation of the Root Foldername directory on the FTP server.
Dragging it over again, it copied 1 file and created 1 more subdirectory before failing.
I've changed the following settings in Preferences for troubleshooting purposes, but the behavior remains:
Transfer\Common Options\Preserve Timestamp - Disabled
Transfer\Common Options\Calculate Total Size - Disabled
Transfer\Background\Maximum Number of Transfers - 1
Any ideas? I'm having a hard time getting Serv-U to work with SSH.
THANKS!!!!
Brian Krontz
. 2008-07-14 12:03:00.658 Ascii transfer mode selected.
. 2008-07-14 12:03:00.658 Opening remote file.
> 2008-07-14 12:03:00.658 Type: SSH_FXP_OPEN, Size: 77, Number: 1790979
. 2008-07-14 12:03:00.658 Sent 81 bytes
. 2008-07-14 12:03:00.658 There are 0 bytes remaining in the send buffer
. 2008-07-14 12:03:00.658 Waiting for another 4 bytes
. 2008-07-14 12:03:00.674 Detected network event
. 2008-07-14 12:03:00.674 Received 17 bytes (0)
. 2008-07-14 12:03:00.674 Read 4 bytes (13 pending)
. 2008-07-14 12:03:00.674 Read 13 bytes (0 pending)
< 2008-07-14 12:03:00.674 Type: SSH_FXP_HANDLE, Size: 13, Number: 1790979
> 2008-07-14 12:03:00.674 Type: SSH_FXP_WRITE, Size: 139, Number: 1791494
. 2008-07-14 12:03:00.674 Sent 143 bytes
. 2008-07-14 12:03:00.674 There are 0 bytes remaining in the send buffer
> 2008-07-14 12:03:00.674 Type: SSH_FXP_CLOSE, Size: 13, Number: 1791748
. 2008-07-14 12:03:00.674 Sent 17 bytes
. 2008-07-14 12:03:00.674 Waiting for another 4 bytes
. 2008-07-14 12:03:00.689 Detected network event
. 2008-07-14 12:03:00.689 Received 31 bytes (0)
. 2008-07-14 12:03:00.689 Read 4 bytes (27 pending)
. 2008-07-14 12:03:00.689 Read 27 bytes (0 pending)
< 2008-07-14 12:03:00.689 Type: SSH_FXP_STATUS, Size: 27, Number: 1791494
. 2008-07-14 12:03:00.689 Waiting for another 4 bytes
. 2008-07-14 12:03:00.705 Detected network event
. 2008-07-14 12:03:00.705 Received 31 bytes (0)
. 2008-07-14 12:03:00.705 Read 4 bytes (27 pending)
. 2008-07-14 12:03:00.705 Read 27 bytes (0 pending)
< 2008-07-14 12:03:00.705 Type: SSH_FXP_STATUS, Size: 27, Number: 1791748
< 2008-07-14 12:03:00.705 Status/error code: 0
. 2008-07-14 12:03:00.705 File: "U:\LocalFile/Foldername/Subfoldername"
. 2008-07-14 12:03:00.705 Trying to open directory "/D:/FTP/Username/Foldername/Subfoldername/".
> 2008-07-14 12:03:00.705 Type: SSH_FXP_LSTAT, Size: 48, Number: 1792007
. 2008-07-14 12:03:00.705 Sent 52 bytes
. 2008-07-14 12:03:00.705 There are 0 bytes remaining in the send buffer
. 2008-07-14 12:03:00.705 Waiting for another 4 bytes
. 2008-07-14 12:03:00.721 Detected network event
. 2008-07-14 12:03:00.721 Received 36 bytes (0)
. 2008-07-14 12:03:00.721 Read 4 bytes (32 pending)
. 2008-07-14 12:03:00.721 Read 32 bytes (0 pending)
< 2008-07-14 12:03:00.721 Type: SSH_FXP_STATUS, Size: 32, Number: 1792007
< 2008-07-14 12:03:00.721 Status/error code: 2, Message: 1792007, Server: No such file., Language: en
. 2008-07-14 12:03:00.721 Creating directory "/D:/FTP/Username/Foldername/Subfoldername/".
. 2008-07-14 12:03:00.721 Canonifying: "/D:/FTP/Username/Foldername/Subfoldername/"
. 2008-07-14 12:03:00.721 Getting real path for '/D:/FTP/Username/Foldername/Subfoldername/'
> 2008-07-14 12:03:00.721 Type: SSH_FXP_REALPATH, Size: 44, Number: 1792528
. 2008-07-14 12:03:00.721 Sent 48 bytes
. 2008-07-14 12:03:00.721 There are 0 bytes remaining in the send buffer
. 2008-07-14 12:03:00.721 Waiting for another 4 bytes
. 2008-07-14 12:03:00.736 Detected network event
. 2008-07-14 12:03:00.736 Received 36 bytes (0)
. 2008-07-14 12:03:00.736 Read 4 bytes (32 pending)
. 2008-07-14 12:03:00.736 Read 32 bytes (0 pending)
< 2008-07-14 12:03:00.736 Type: SSH_FXP_STATUS, Size: 32, Number: 1792528
< 2008-07-14 12:03:00.736 Status/error code: 2, Message: 1792528, Server: No such file., Language: en
. 2008-07-14 12:03:00.736 Getting real path for '/D:/FTP/Username/Foldername/'
> 2008-07-14 12:03:00.736 Type: SSH_FXP_REALPATH, Size: 36, Number: 1792784
. 2008-07-14 12:03:00.736 Sent 40 bytes
. 2008-07-14 12:03:00.736 There are 0 bytes remaining in the send buffer
. 2008-07-14 12:03:00.736 Waiting for another 4 bytes
. 2008-07-14 12:03:00.768 Detected network event
. 2008-07-14 12:03:00.768 Received 101 bytes (0)
. 2008-07-14 12:03:00.768 Read 4 bytes (97 pending)
. 2008-07-14 12:03:00.768 Read 97 bytes (0 pending)
< 2008-07-14 12:03:00.768 Type: SSH_FXP_NAME, Size: 97, Number: 1792784
. 2008-07-14 12:03:00.768 Real path is '/D:/FTP/Username/Foldername/'
. 2008-07-14 12:03:00.768 Canonified: "/D:/FTP/Username/Foldername/"
> 2008-07-14 12:03:00.768 Type: SSH_FXP_MKDIR, Size: 48, Number: 1792270
. 2008-07-14 12:03:00.768 Sent 52 bytes
. 2008-07-14 12:03:00.768 There are 0 bytes remaining in the send buffer
. 2008-07-14 12:03:00.768 Waiting for another 4 bytes
. 2008-07-14 12:03:00.799 Detected network event
. 2008-07-14 12:03:00.799 Received 31 bytes (0)
. 2008-07-14 12:03:00.799 Read 4 bytes (27 pending)
. 2008-07-14 12:03:00.799 Read 27 bytes (0 pending)
< 2008-07-14 12:03:00.799 Type: SSH_FXP_STATUS, Size: 27, Number: 1792270
< 2008-07-14 12:03:00.799 Status/error code: 0
> 2008-07-14 12:03:00.799 Type: SSH_FXP_SETSTAT, Size: 48, Number: 1793033
. 2008-07-14 12:03:00.799 Sent 52 bytes
. 2008-07-14 12:03:00.799 There are 0 bytes remaining in the send buffer
. 2008-07-14 12:03:00.799 Waiting for another 4 bytes
. 2008-07-14 12:03:00.814 Detected network event
. 2008-07-14 12:03:00.814 Received 53 bytes (0)
. 2008-07-14 12:03:00.814 Read 4 bytes (49 pending)
. 2008-07-14 12:03:00.814 Read 49 bytes (0 pending)
< 2008-07-14 12:03:00.814 Type: SSH_FXP_STATUS, Size: 49, Number: 1793033
< 2008-07-14 12:03:00.814 Status/error code: 24, Message: 1793033, Server: Specified file is a directory., Language: en
. 2008-07-14 12:03:00.814 Asking user:
. 2008-07-14 12:03:00.814 Error creating folder '/D:/FTP/Username/Foldername/Subfoldername/'. ("Cannot change properties of file '/D:/FTP/Username/Foldername/Subfoldername/'.","The specifed file was a directory in a context where a directory cannot be used.
. 2008-07-14 12:03:00.814 Error code: 24
. 2008-07-14 12:03:00.814 Error message from server (en): Specified file is a directory.
. 2008-07-14 12:03:00.814 Request code: 9")
. 2008-07-14 12:03:00.830 Session upkeep
. 2008-07-14 12:03:01.268 Session upkeep
. 2008-07-14 12:03:01.768 Session upkeep
. 2008-07-14 12:03:02.268 Session upkeep
This is the log while on debug level 2
. 2008-07-15 10:24:48.909 --------------------------------------------------------------------------
. 2008-07-15 10:24:48.909 WinSCP Version 4.1.5 (Build 410) (OS 5.1.2600 Service Pack 3)
. 2008-07-15 10:24:48.909 Login time: Tuesday, July 15, 2008 10:24:48 AM
. 2008-07-15 10:24:48.909 Session name: bkrontzadmin@secureftp.teamrls.com
. 2008-07-15 10:24:48.909 Host name: secureftp.teamrls.com (Port: 22)
. 2008-07-15 10:24:48.909 User name: bkrontzadmin (Password: Yes, Key file: No)
. 2008-07-15 10:24:48.909 Tunnel: No
. 2008-07-15 10:24:48.909 Transfer Protocol: SFTP (SCP)
. 2008-07-15 10:24:48.909 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-07-15 10:24:48.909 Proxy: none
. 2008-07-15 10:24:48.909 SSH protocol version: 2; Compression: No
. 2008-07-15 10:24:48.909 Bypass authentication: No
. 2008-07-15 10:24:48.909 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-07-15 10:24:48.909 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2008-07-15 10:24:48.909 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-07-15 10:24:48.909 SFTP Bugs: -,-
. 2008-07-15 10:24:48.909 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-07-15 10:24:48.909 Shell: default, EOL: 0
. 2008-07-15 10:24:48.909 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-07-15 10:24:48.909 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2008-07-15 10:24:48.909 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-07-15 10:24:48.909 Cache directory changes: Yes, Permanent: Yes
. 2008-07-15 10:24:48.909 DST mode: 1
. 2008-07-15 10:24:48.925 Looking up host "secureftp.teamrls.com"
. 2008-07-15 10:24:48.925 Connecting to 38.98.97.35 port 22
. 2008-07-15 10:24:48.940 Selecting events 63 for socket 596
. 2008-07-15 10:24:48.940 Waiting for the server to continue with the initialisation
. 2008-07-15 10:24:48.940 Looking for incoming data
. 2008-07-15 10:24:48.940 Looking for network events
. 2008-07-15 10:24:48.940 Detected network event
. 2008-07-15 10:24:48.940 Enumerating network events for socket 596
. 2008-07-15 10:24:48.940 Enumerated 18 network events making 18 cumulative events for socket 596
. 2008-07-15 10:24:48.940 Handling network write event on socket 596 with error 0
. 2008-07-15 10:24:48.940 Handling network connect event on socket 596 with error 0
. 2008-07-15 10:24:48.956 Detected network event
. 2008-07-15 10:24:48.956 Enumerating network events for socket 596
. 2008-07-15 10:24:48.956 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:48.956 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:48.956 Server version: SSH-2.0-Serv-U_7.2.0.0
. 2008-07-15 10:24:48.956 We claim version: SSH-2.0-WinSCP_release_4.1.5
. 2008-07-15 10:24:48.956 SSPI: acquired credentials for: Administrator@KRONTZ.LOCAL
. 2008-07-15 10:24:48.956 Constructed service principal name 'host/secureftp.teamrls.com'
. 2008-07-15 10:24:48.956 GSSKEX disabled: The specified target is unknown or unreachable
. 2008-07-15 10:24:48.956 Using SSH protocol version 2
. 2008-07-15 10:24:48.956 Waiting for the server to continue with the initialisation
. 2008-07-15 10:24:48.956 Looking for incoming data
. 2008-07-15 10:24:48.956 Looking for network events
. 2008-07-15 10:24:48.971 Detected network event
. 2008-07-15 10:24:48.971 Enumerating network events for socket 596
. 2008-07-15 10:24:48.971 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:48.971 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:48.971 Using Diffie-Hellman with standard group "group1"
. 2008-07-15 10:24:48.971 Doing Diffie-Hellman key exchange with hash SHA-1
. 2008-07-15 10:24:48.987 Waiting for the server to continue with the initialisation
. 2008-07-15 10:24:48.987 Looking for incoming data
. 2008-07-15 10:24:48.987 Looking for network events
. 2008-07-15 10:24:49.190 Detected network event
. 2008-07-15 10:24:49.190 Enumerating network events for socket 596
. 2008-07-15 10:24:49.190 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:49.190 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:49.237 Selecting events 63 for socket 596
. 2008-07-15 10:24:49.237 Host key fingerprint is:
. 2008-07-15 10:24:49.237 ssh-dss 1024 f1:b6:07:cd:4a:b7:80:df:e2:94:ad:a8:f8:25:8d:25
. 2008-07-15 10:24:49.237 Initialised AES-256 CBC client->server encryption
. 2008-07-15 10:24:49.237 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-07-15 10:24:49.237 Waiting for the server to continue with the initialisation
. 2008-07-15 10:24:49.237 Looking for incoming data
. 2008-07-15 10:24:49.237 Looking for network events
. 2008-07-15 10:24:49.237 Detected network event
. 2008-07-15 10:24:49.237 Enumerating network events for socket 596
. 2008-07-15 10:24:49.237 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:49.237 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:49.237 Initialised AES-256 CBC server->client encryption
. 2008-07-15 10:24:49.237 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-07-15 10:24:49.253 Detected network event
. 2008-07-15 10:24:49.253 Enumerating network events for socket 596
. 2008-07-15 10:24:49.253 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:49.253 Handling network read event on socket 596 with error 0
! 2008-07-15 10:24:49.253 Using username "bkrontzadmin".
. 2008-07-15 10:24:49.253 Waiting for the server to continue with the initialisation
. 2008-07-15 10:24:49.253 Looking for incoming data
. 2008-07-15 10:24:49.253 Looking for network events
. 2008-07-15 10:24:49.268 Detected network event
. 2008-07-15 10:24:49.268 Enumerating network events for socket 596
. 2008-07-15 10:24:49.268 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:49.268 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:49.268 Prompt (6, SSH password, , &Password: )
. 2008-07-15 10:24:49.268 Using stored password.
. 2008-07-15 10:24:49.268 Sent password
. 2008-07-15 10:24:49.268 Waiting for the server to continue with the initialisation
. 2008-07-15 10:24:49.268 Looking for incoming data
. 2008-07-15 10:24:49.268 Looking for network events
. 2008-07-15 10:24:49.284 Detected network event
. 2008-07-15 10:24:49.284 Enumerating network events for socket 596
. 2008-07-15 10:24:49.284 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:49.284 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:49.284 Access granted
. 2008-07-15 10:24:49.284 Waiting for the server to continue with the initialisation
. 2008-07-15 10:24:49.284 Looking for incoming data
. 2008-07-15 10:24:49.284 Looking for network events
. 2008-07-15 10:24:49.300 Detected network event
. 2008-07-15 10:24:49.300 Enumerating network events for socket 596
. 2008-07-15 10:24:49.300 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:49.300 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:49.300 Opened channel for session
. 2008-07-15 10:24:49.300 Waiting for the server to continue with the initialisation
. 2008-07-15 10:24:49.300 Looking for incoming data
. 2008-07-15 10:24:49.300 Looking for network events
. 2008-07-15 10:24:49.315 Detected network event
. 2008-07-15 10:24:49.315 Enumerating network events for socket 596
. 2008-07-15 10:24:49.315 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:49.315 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:49.315 Started a shell/command
. 2008-07-15 10:24:49.315 --------------------------------------------------------------------------
. 2008-07-15 10:24:49.315 Using SFTP protocol.
. 2008-07-15 10:24:49.315 Doing startup conversation with host.
> 2008-07-15 10:24:49.315 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2008-07-15 10:24:49.315 01,00,00,00,05,
. 2008-07-15 10:24:49.315 Sent 9 bytes
. 2008-07-15 10:24:49.315 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:24:49.315 Looking for network events
. 2008-07-15 10:24:49.315 Timeout waiting for network events
. 2008-07-15 10:24:49.315 Waiting for another 4 bytes
. 2008-07-15 10:24:49.315 Looking for incoming data
. 2008-07-15 10:24:49.331 Detected network event
. 2008-07-15 10:24:49.331 Enumerating network events for socket 596
. 2008-07-15 10:24:49.331 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:49.331 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:49.331 Received 9 bytes (0)
. 2008-07-15 10:24:49.331 Read 4 bytes (5 pending)
. 2008-07-15 10:24:49.331 Read 5 bytes (0 pending)
< 2008-07-15 10:24:49.331 Type: SSH_FXP_VERSION, Size: 5, Number: -1
< 2008-07-15 10:24:49.331 02,00,00,00,04,
. 2008-07-15 10:24:49.331 SFTP version 4 negotiated.
. 2008-07-15 10:24:49.331 We will use UTF-8 strings when appropriate
. 2008-07-15 10:24:49.331 Getting current directory name.
. 2008-07-15 10:24:49.331 Getting real path for '.'
> 2008-07-15 10:24:49.331 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2008-07-15 10:24:49.331 10,00,00,00,10,00,00,00,01,2E,
. 2008-07-15 10:24:49.331 Sent 14 bytes
. 2008-07-15 10:24:49.346 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:24:49.346 Looking for network events
. 2008-07-15 10:24:49.346 Timeout waiting for network events
. 2008-07-15 10:24:49.346 Waiting for another 4 bytes
. 2008-07-15 10:24:49.346 Looking for incoming data
. 2008-07-15 10:24:49.346 Detected network event
. 2008-07-15 10:24:49.346 Enumerating network events for socket 596
. 2008-07-15 10:24:49.346 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:49.346 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:49.346 Received 87 bytes (0)
. 2008-07-15 10:24:49.346 Read 4 bytes (83 pending)
. 2008-07-15 10:24:49.346 Read 83 bytes (0 pending)
< 2008-07-15 10:24:49.346 Type: SSH_FXP_NAME, Size: 83, Number: 16
< 2008-07-15 10:24:49.346 68,00,00,00,10,00,00,00,01,00,00,00,0C,2F,44,3A,2F,46,54,50,2F,69,74,6D,70,
< 2008-07-15 10:24:49.346 00,00,00,BD,00,00,00,00,00,00,00,00,00,00,00,00,04,75,73,65,72,00,00,00,05,
< 2008-07-15 10:24:49.346 67,72,6F,75,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
< 2008-07-15 10:24:49.362 00,00,00,00,00,00,00,00,
. 2008-07-15 10:24:49.362 Real path is '/D:/FTP/itmp'
. 2008-07-15 10:24:49.362 Listing directory "/D:/FTP/itmp".
> 2008-07-15 10:24:49.362 Type: SSH_FXP_OPENDIR, Size: 21, Number: 267
> 2008-07-15 10:24:49.362 0B,00,00,01,0B,00,00,00,0C,2F,44,3A,2F,46,54,50,2F,69,74,6D,70,
. 2008-07-15 10:24:49.362 Sent 25 bytes
. 2008-07-15 10:24:49.362 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:24:49.362 Looking for network events
. 2008-07-15 10:24:49.362 Timeout waiting for network events
. 2008-07-15 10:24:49.362 Waiting for another 4 bytes
. 2008-07-15 10:24:49.362 Looking for incoming data
. 2008-07-15 10:24:49.378 Detected network event
. 2008-07-15 10:24:49.378 Enumerating network events for socket 596
. 2008-07-15 10:24:49.378 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:49.378 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:49.378 Received 17 bytes (0)
. 2008-07-15 10:24:49.378 Read 4 bytes (13 pending)
. 2008-07-15 10:24:49.378 Read 13 bytes (0 pending)
< 2008-07-15 10:24:49.378 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
< 2008-07-15 10:24:49.378 66,00,00,01,0B,00,00,00,04,00,00,00,00,
> 2008-07-15 10:24:49.378 Type: SSH_FXP_READDIR, Size: 13, Number: 524
> 2008-07-15 10:24:49.378 0C,00,00,02,0C,00,00,00,04,00,00,00,00,
. 2008-07-15 10:24:49.378 Sent 17 bytes
. 2008-07-15 10:24:49.378 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:24:49.378 Looking for network events
. 2008-07-15 10:24:49.378 Timeout waiting for network events
. 2008-07-15 10:24:49.378 Waiting for another 4 bytes
. 2008-07-15 10:24:49.378 Looking for incoming data
. 2008-07-15 10:24:49.378 Received 149 bytes (0)
. 2008-07-15 10:24:49.378 Read 4 bytes (145 pending)
. 2008-07-15 10:24:49.378 Read 145 bytes (0 pending)
< 2008-07-15 10:24:49.378 Type: SSH_FXP_NAME, Size: 145, Number: 524
< 2008-07-15 10:24:49.378 68,00,00,02,0C,00,00,00,02,00,00,00,09,72,68,69,6E,6F,73,6F,66,74,00,00,00,
< 2008-07-15 10:24:49.378 BD,02,00,00,00,00,00,00,00,00,00,00,00,04,75,73,65,72,00,00,00,05,67,72,6F,
< 2008-07-15 10:24:49.378 75,70,00,00,41,B6,00,00,00,00,48,7C,4B,0E,00,00,00,00,48,77,84,62,00,00,00,
< 2008-07-15 10:24:49.378 00,48,77,AB,2C,00,00,00,03,53,51,45,00,00,00,BD,02,00,00,00,00,00,00,00,00,
< 2008-07-15 10:24:49.378 00,00,00,04,75,73,65,72,00,00,00,05,67,72,6F,75,70,00,00,41,B6,00,00,00,00,
< 2008-07-15 10:24:49.378 48,7C,4B,0E,00,00,00,00,47,E3,D3,5B,00,00,00,00,48,44,EB,F0,
> 2008-07-15 10:24:49.378 Type: SSH_FXP_READDIR, Size: 13, Number: 780
> 2008-07-15 10:24:49.378 0C,00,00,03,0C,00,00,00,04,00,00,00,00,
. 2008-07-15 10:24:49.378 Read file 'rhinosoft' from listing
. 2008-07-15 10:24:49.378 Read file 'SQE' from listing
. 2008-07-15 10:24:49.393 Detected network event
. 2008-07-15 10:24:49.393 Enumerating network events for socket 596
. 2008-07-15 10:24:49.393 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:49.393 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:49.393 Received 35 bytes (0)
. 2008-07-15 10:24:49.393 Read 4 bytes (31 pending)
. 2008-07-15 10:24:49.393 Read 31 bytes (0 pending)
< 2008-07-15 10:24:49.393 Type: SSH_FXP_STATUS, Size: 31, Number: 780
< 2008-07-15 10:24:49.393 65,00,00,03,0C,00,00,00,01,00,00,00,0C,45,6E,64,20,6F,66,20,66,69,6C,65,2E,
< 2008-07-15 10:24:49.393 00,00,00,02,65,6E,
< 2008-07-15 10:24:49.393 Status/error code: 1
> 2008-07-15 10:24:49.393 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
> 2008-07-15 10:24:49.393 04,00,00,04,04,00,00,00,04,00,00,00,00,
. 2008-07-15 10:24:49.393 Sent 17 bytes
. 2008-07-15 10:24:49.393 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:24:49.393 Looking for network events
. 2008-07-15 10:24:49.393 Timeout waiting for network events
. 2008-07-15 10:24:49.393 Startup conversation with host finished.
. 2008-07-15 10:24:50.096 Session upkeep
. 2008-07-15 10:24:50.096 Looking for network events
. 2008-07-15 10:24:50.096 Detected network event
. 2008-07-15 10:24:50.096 Enumerating network events for socket 596
. 2008-07-15 10:24:50.096 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:24:50.096 Handling network read event on socket 596 with error 0
. 2008-07-15 10:24:50.096 Received 31 bytes (0)
. 2008-07-15 10:24:50.612 Session upkeep
. 2008-07-15 10:24:50.612 Looking for network events
. 2008-07-15 10:24:50.612 Timeout waiting for network events
. 2008-07-15 10:24:51.128 Session upkeep
. 2008-07-15 10:24:51.128 Looking for network events
. 2008-07-15 10:24:51.128 Timeout waiting for network events
. 2008-07-15 10:24:51.628 Session upkeep
. 2008-07-15 10:24:51.628 Looking for network events
. 2008-07-15 10:24:51.628 Timeout waiting for network events
. 2008-07-15 10:24:52.128 Session upkeep
. 2008-07-15 10:24:52.128 Looking for network events
. 2008-07-15 10:24:52.128 Timeout waiting for network events
. 2008-07-15 10:24:52.628 Session upkeep
. 2008-07-15 10:24:52.628 Looking for network events
. 2008-07-15 10:24:52.628 Timeout waiting for network events
. 2008-07-15 10:24:53.128 Session upkeep
. 2008-07-15 10:24:53.128 Looking for network events
. 2008-07-15 10:24:53.128 Timeout waiting for network events
. 2008-07-15 10:24:53.628 Session upkeep
. 2008-07-15 10:24:53.628 Looking for network events
. 2008-07-15 10:24:53.628 Timeout waiting for network events
. 2008-07-15 10:24:54.128 Session upkeep
. 2008-07-15 10:24:54.128 Looking for network events
. 2008-07-15 10:24:54.128 Timeout waiting for network events
. 2008-07-15 10:24:54.628 Session upkeep
. 2008-07-15 10:24:54.628 Looking for network events
. 2008-07-15 10:24:54.628 Timeout waiting for network events
. 2008-07-15 10:24:55.128 Session upkeep
. 2008-07-15 10:24:55.128 Looking for network events
. 2008-07-15 10:24:55.128 Timeout waiting for network events
. 2008-07-15 10:24:55.628 Session upkeep
. 2008-07-15 10:24:55.628 Looking for network events
. 2008-07-15 10:24:55.628 Timeout waiting for network events
. 2008-07-15 10:24:56.128 Session upkeep
. 2008-07-15 10:24:56.128 Looking for network events
. 2008-07-15 10:24:56.128 Timeout waiting for network events
. 2008-07-15 10:24:56.628 Session upkeep
. 2008-07-15 10:24:56.628 Looking for network events
. 2008-07-15 10:24:56.628 Timeout waiting for network events
. 2008-07-15 10:24:57.128 Session upkeep
. 2008-07-15 10:24:57.128 Looking for network events
. 2008-07-15 10:24:57.128 Timeout waiting for network events
. 2008-07-15 10:24:57.628 Session upkeep
. 2008-07-15 10:24:57.628 Looking for network events
. 2008-07-15 10:24:57.628 Timeout waiting for network events
. 2008-07-15 10:24:58.128 Session upkeep
. 2008-07-15 10:24:58.128 Looking for network events
. 2008-07-15 10:24:58.128 Timeout waiting for network events
. 2008-07-15 10:24:58.628 Session upkeep
. 2008-07-15 10:24:58.628 Looking for network events
. 2008-07-15 10:24:58.628 Timeout waiting for network events
. 2008-07-15 10:24:59.128 Session upkeep
. 2008-07-15 10:24:59.128 Looking for network events
. 2008-07-15 10:24:59.128 Timeout waiting for network events
. 2008-07-15 10:24:59.628 Session upkeep
. 2008-07-15 10:24:59.628 Looking for network events
. 2008-07-15 10:24:59.628 Timeout waiting for network events
. 2008-07-15 10:25:00.128 Session upkeep
. 2008-07-15 10:25:00.128 Looking for network events
. 2008-07-15 10:25:00.128 Timeout waiting for network events
. 2008-07-15 10:25:00.628 Session upkeep
. 2008-07-15 10:25:00.628 Looking for network events
. 2008-07-15 10:25:00.628 Timeout waiting for network events
. 2008-07-15 10:25:01.128 Session upkeep
. 2008-07-15 10:25:01.128 Looking for network events
. 2008-07-15 10:25:01.128 Timeout waiting for network events
. 2008-07-15 10:25:01.628 Session upkeep
. 2008-07-15 10:25:01.628 Looking for network events
. 2008-07-15 10:25:01.628 Timeout waiting for network events
. 2008-07-15 10:25:02.128 Session upkeep
. 2008-07-15 10:25:02.128 Looking for network events
. 2008-07-15 10:25:02.128 Timeout waiting for network events
. 2008-07-15 10:25:02.628 Session upkeep
. 2008-07-15 10:25:02.628 Looking for network events
. 2008-07-15 10:25:02.628 Timeout waiting for network events
. 2008-07-15 10:25:03.128 Session upkeep
. 2008-07-15 10:25:03.128 Looking for network events
. 2008-07-15 10:25:03.128 Timeout waiting for network events
. 2008-07-15 10:25:03.628 Session upkeep
. 2008-07-15 10:25:03.628 Looking for network events
. 2008-07-15 10:25:03.628 Timeout waiting for network events
. 2008-07-15 10:25:04.128 Session upkeep
. 2008-07-15 10:25:04.128 Looking for network events
. 2008-07-15 10:25:04.128 Timeout waiting for network events
. 2008-07-15 10:25:04.628 Session upkeep
. 2008-07-15 10:25:04.628 Looking for network events
. 2008-07-15 10:25:04.628 Timeout waiting for network events
. 2008-07-15 10:25:05.128 Session upkeep
. 2008-07-15 10:25:05.128 Looking for network events
. 2008-07-15 10:25:05.128 Timeout waiting for network events
. 2008-07-15 10:25:05.628 Session upkeep
. 2008-07-15 10:25:05.628 Looking for network events
. 2008-07-15 10:25:05.628 Timeout waiting for network events
. 2008-07-15 10:25:06.128 Session upkeep
. 2008-07-15 10:25:06.128 Looking for network events
. 2008-07-15 10:25:06.128 Timeout waiting for network events
. 2008-07-15 10:25:06.347 Copying 1 files/directories to remote directory "/D:/FTP/itmp/"
. 2008-07-15 10:25:06.347 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2008-07-15 10:25:06.347 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2008-07-15 10:25:06.347 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2008-07-15 10:25:06.347 File: "C:\Foldername"
. 2008-07-15 10:25:06.347 Trying to open directory "/D:/FTP/itmp/Foldername/".
> 2008-07-15 10:25:06.347 Type: SSH_FXP_LSTAT, Size: 37, Number: 1287
> 2008-07-15 10:25:06.363 07,00,00,05,07,00,00,00,18,2F,44,3A,2F,46,54,50,2F,69,74,6D,70,2F,46,6F,6C,
> 2008-07-15 10:25:06.363 64,65,72,6E,61,6D,65,2F,00,00,00,AD,
. 2008-07-15 10:25:06.363 Sent 41 bytes
. 2008-07-15 10:25:06.363 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:25:06.363 Looking for network events
. 2008-07-15 10:25:06.363 Timeout waiting for network events
. 2008-07-15 10:25:06.363 Read 4 bytes (27 pending)
. 2008-07-15 10:25:06.363 Read 27 bytes (0 pending)
< 2008-07-15 10:25:06.363 Type: SSH_FXP_STATUS, Size: 27, Number: 1028
< 2008-07-15 10:25:06.363 65,00,00,04,04,00,00,00,00,00,00,00,08,53,75,63,63,65,73,73,2E,00,00,00,02,
< 2008-07-15 10:25:06.363 65,6E,
. 2008-07-15 10:25:06.363 Discarding reserved response
. 2008-07-15 10:25:06.363 Waiting for another 4 bytes
. 2008-07-15 10:25:06.363 Looking for incoming data
. 2008-07-15 10:25:06.394 Detected network event
. 2008-07-15 10:25:06.394 Enumerating network events for socket 596
. 2008-07-15 10:25:06.394 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:25:06.394 Handling network read event on socket 596 with error 0
. 2008-07-15 10:25:06.394 Received 36 bytes (0)
. 2008-07-15 10:25:06.394 Read 4 bytes (32 pending)
. 2008-07-15 10:25:06.394 Read 32 bytes (0 pending)
< 2008-07-15 10:25:06.394 Type: SSH_FXP_STATUS, Size: 32, Number: 1287
< 2008-07-15 10:25:06.394 65,00,00,05,07,00,00,00,02,00,00,00,0D,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2008-07-15 10:25:06.394 2E,00,00,00,02,65,6E,
< 2008-07-15 10:25:06.394 Status/error code: 2, Message: 1287, Server: No such file., Language: en
. 2008-07-15 10:25:06.409 Creating directory "/D:/FTP/itmp/Foldername/".
. 2008-07-15 10:25:06.409 Canonifying: "/D:/FTP/itmp/Foldername/"
. 2008-07-15 10:25:06.409 Getting real path for '/D:/FTP/itmp/Foldername/'
> 2008-07-15 10:25:06.409 Type: SSH_FXP_REALPATH, Size: 33, Number: 1808
> 2008-07-15 10:25:06.409 10,00,00,07,10,00,00,00,18,2F,44,3A,2F,46,54,50,2F,69,74,6D,70,2F,46,6F,6C,
> 2008-07-15 10:25:06.409 64,65,72,6E,61,6D,65,2F,
. 2008-07-15 10:25:06.409 Sent 37 bytes
. 2008-07-15 10:25:06.409 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:25:06.409 Looking for network events
. 2008-07-15 10:25:06.409 Timeout waiting for network events
. 2008-07-15 10:25:06.409 Waiting for another 4 bytes
. 2008-07-15 10:25:06.409 Looking for incoming data
. 2008-07-15 10:25:06.409 Detected network event
. 2008-07-15 10:25:06.409 Enumerating network events for socket 596
. 2008-07-15 10:25:06.409 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:25:06.409 Handling network read event on socket 596 with error 0
. 2008-07-15 10:25:06.409 Received 36 bytes (0)
. 2008-07-15 10:25:06.409 Read 4 bytes (32 pending)
. 2008-07-15 10:25:06.409 Read 32 bytes (0 pending)
< 2008-07-15 10:25:06.409 Type: SSH_FXP_STATUS, Size: 32, Number: 1808
< 2008-07-15 10:25:06.409 65,00,00,07,10,00,00,00,02,00,00,00,0D,4E,6F,20,73,75,63,68,20,66,69,6C,65,
< 2008-07-15 10:25:06.409 2E,00,00,00,02,65,6E,
< 2008-07-15 10:25:06.409 Status/error code: 2, Message: 1808, Server: No such file., Language: en
. 2008-07-15 10:25:06.409 Getting real path for '/D:/FTP/itmp/'
> 2008-07-15 10:25:06.409 Type: SSH_FXP_REALPATH, Size: 22, Number: 2064
> 2008-07-15 10:25:06.409 10,00,00,08,10,00,00,00,0D,2F,44,3A,2F,46,54,50,2F,69,74,6D,70,2F,
. 2008-07-15 10:25:06.409 Sent 26 bytes
. 2008-07-15 10:25:06.425 Detected network event
. 2008-07-15 10:25:06.425 Enumerating network events for socket 596
. 2008-07-15 10:25:06.425 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:25:06.425 Handling network read event on socket 596 with error 0
. 2008-07-15 10:25:06.425 Received 87 bytes (0)
. 2008-07-15 10:25:06.425 Read 4 bytes (83 pending)
. 2008-07-15 10:25:06.425 Read 83 bytes (0 pending)
< 2008-07-15 10:25:06.425 Type: SSH_FXP_NAME, Size: 83, Number: 2064
< 2008-07-15 10:25:06.425 68,00,00,08,10,00,00,00,01,00,00,00,0C,2F,44,3A,2F,46,54,50,2F,69,74,6D,70,
< 2008-07-15 10:25:06.425 00,00,00,BD,00,00,00,00,00,00,00,00,00,00,00,00,04,75,73,65,72,00,00,00,05,
< 2008-07-15 10:25:06.425 67,72,6F,75,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
< 2008-07-15 10:25:06.425 00,00,00,00,00,00,00,00,
. 2008-07-15 10:25:06.425 Real path is '/D:/FTP/itmp'
. 2008-07-15 10:25:06.425 Canonified: "/D:/FTP/itmp/Foldername"
> 2008-07-15 10:25:06.425 Type: SSH_FXP_MKDIR, Size: 37, Number: 1550
> 2008-07-15 10:25:06.425 0E,00,00,06,0E,00,00,00,17,2F,44,3A,2F,46,54,50,2F,69,74,6D,70,2F,46,6F,6C,
> 2008-07-15 10:25:06.425 64,65,72,6E,61,6D,65,00,00,00,00,02,
. 2008-07-15 10:25:06.425 Sent 41 bytes
. 2008-07-15 10:25:06.425 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:25:06.425 Looking for network events
. 2008-07-15 10:25:06.425 Timeout waiting for network events
. 2008-07-15 10:25:06.425 Waiting for another 4 bytes
. 2008-07-15 10:25:06.425 Looking for incoming data
. 2008-07-15 10:25:06.441 Detected network event
. 2008-07-15 10:25:06.441 Enumerating network events for socket 596
. 2008-07-15 10:25:06.441 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:25:06.441 Handling network read event on socket 596 with error 0
. 2008-07-15 10:25:06.441 Received 31 bytes (0)
. 2008-07-15 10:25:06.441 Read 4 bytes (27 pending)
. 2008-07-15 10:25:06.441 Read 27 bytes (0 pending)
< 2008-07-15 10:25:06.441 Type: SSH_FXP_STATUS, Size: 27, Number: 1550
< 2008-07-15 10:25:06.441 65,00,00,06,0E,00,00,00,00,00,00,00,08,53,75,63,63,65,73,73,2E,00,00,00,02,
< 2008-07-15 10:25:06.441 65,6E,
< 2008-07-15 10:25:06.441 Status/error code: 0
> 2008-07-15 10:25:06.441 Type: SSH_FXP_SETSTAT, Size: 37, Number: 2313
> 2008-07-15 10:25:06.441 09,00,00,09,09,00,00,00,17,2F,44,3A,2F,46,54,50,2F,69,74,6D,70,2F,46,6F,6C,
> 2008-07-15 10:25:06.441 64,65,72,6E,61,6D,65,00,00,00,00,02,
. 2008-07-15 10:25:06.456 Sent 41 bytes
. 2008-07-15 10:25:06.456 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:25:06.456 Looking for network events
. 2008-07-15 10:25:06.456 Timeout waiting for network events
. 2008-07-15 10:25:06.456 Waiting for another 4 bytes
. 2008-07-15 10:25:06.456 Looking for incoming data
. 2008-07-15 10:25:06.456 Detected network event
. 2008-07-15 10:25:06.456 Enumerating network events for socket 596
. 2008-07-15 10:25:06.456 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:25:06.456 Handling network read event on socket 596 with error 0
. 2008-07-15 10:25:06.456 Received 53 bytes (0)
. 2008-07-15 10:25:06.456 Read 4 bytes (49 pending)
. 2008-07-15 10:25:06.456 Read 49 bytes (0 pending)
< 2008-07-15 10:25:06.456 Type: SSH_FXP_STATUS, Size: 49, Number: 2313
< 2008-07-15 10:25:06.456 65,00,00,09,09,00,00,00,18,00,00,00,1E,53,70,65,63,69,66,69,65,64,20,66,69,
< 2008-07-15 10:25:06.456 6C,65,20,69,73,20,61,20,64,69,72,65,63,74,6F,72,79,2E,00,00,00,02,65,6E,
< 2008-07-15 10:25:06.472 Status/error code: 24, Message: 2313, Server: Specified file is a directory., Language: en
. 2008-07-15 10:25:06.472 Asking user:
. 2008-07-15 10:25:06.472 Error creating folder '/D:/FTP/itmp/Foldername/'. ("Cannot change properties of file '/D:/FTP/itmp/Foldername/'.","The specifed file was a directory in a context where a directory cannot be used.
. 2008-07-15 10:25:06.472 Error code: 24
. 2008-07-15 10:25:06.472 Error message from server (en): Specified file is a directory.
. 2008-07-15 10:25:06.472 Request code: 9")
. 2008-07-15 10:25:06.628 Session upkeep
. 2008-07-15 10:25:06.628 Looking for network events
. 2008-07-15 10:25:06.628 Timeout waiting for network events
. 2008-07-15 10:25:07.128 Session upkeep
. 2008-07-15 10:25:07.128 Looking for network events
. 2008-07-15 10:25:07.128 Timeout waiting for network events
. 2008-07-15 10:25:07.628 Session upkeep
. 2008-07-15 10:25:07.628 Looking for network events
. 2008-07-15 10:25:07.628 Timeout waiting for network events
. 2008-07-15 10:25:08.128 Session upkeep
. 2008-07-15 10:25:08.128 Looking for network events
. 2008-07-15 10:25:08.128 Timeout waiting for network events
. 2008-07-15 10:25:08.628 Session upkeep
. 2008-07-15 10:25:08.628 Looking for network events
. 2008-07-15 10:25:08.628 Timeout waiting for network events
. 2008-07-15 10:25:09.128 Session upkeep
. 2008-07-15 10:25:09.128 Looking for network events
. 2008-07-15 10:25:09.128 Timeout waiting for network events
. 2008-07-15 10:25:09.628 Session upkeep
. 2008-07-15 10:25:09.628 Looking for network events
. 2008-07-15 10:25:09.628 Timeout waiting for network events
. 2008-07-15 10:25:10.128 Session upkeep
. 2008-07-15 10:25:10.128 Looking for network events
. 2008-07-15 10:25:10.128 Timeout waiting for network events
. 2008-07-15 10:25:10.363 Canonifying: "/D:/FTP/itmp/Foldername/"
. 2008-07-15 10:25:10.363 Getting real path for '/D:/FTP/itmp/Foldername/'
> 2008-07-15 10:25:10.363 Type: SSH_FXP_REALPATH, Size: 33, Number: 2832
> 2008-07-15 10:25:10.363 10,00,00,0B,10,00,00,00,18,2F,44,3A,2F,46,54,50,2F,69,74,6D,70,2F,46,6F,6C,
> 2008-07-15 10:25:10.363 64,65,72,6E,61,6D,65,2F,
. 2008-07-15 10:25:10.363 Sent 37 bytes
. 2008-07-15 10:25:10.363 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:25:10.363 Looking for network events
. 2008-07-15 10:25:10.363 Timeout waiting for network events
. 2008-07-15 10:25:10.363 Waiting for another 4 bytes
. 2008-07-15 10:25:10.363 Looking for incoming data
. 2008-07-15 10:25:10.378 Detected network event
. 2008-07-15 10:25:10.378 Enumerating network events for socket 596
. 2008-07-15 10:25:10.378 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:25:10.378 Handling network read event on socket 596 with error 0
. 2008-07-15 10:25:10.378 Received 98 bytes (0)
. 2008-07-15 10:25:10.378 Read 4 bytes (94 pending)
. 2008-07-15 10:25:10.378 Read 94 bytes (0 pending)
< 2008-07-15 10:25:10.378 Type: SSH_FXP_NAME, Size: 94, Number: 2832
< 2008-07-15 10:25:10.378 68,00,00,0B,10,00,00,00,01,00,00,00,17,2F,44,3A,2F,46,54,50,2F,69,74,6D,70,
< 2008-07-15 10:25:10.378 2F,46,6F,6C,64,65,72,6E,61,6D,65,00,00,00,BD,00,00,00,00,00,00,00,00,00,00,
< 2008-07-15 10:25:10.378 00,00,04,75,73,65,72,00,00,00,05,67,72,6F,75,70,00,00,00,00,00,00,00,00,00,
< 2008-07-15 10:25:10.378 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
. 2008-07-15 10:25:10.378 Real path is '/D:/FTP/itmp/Foldername'
. 2008-07-15 10:25:10.378 Canonified: "/D:/FTP/itmp/Foldername"
> 2008-07-15 10:25:10.378 Type: SSH_FXP_MKDIR, Size: 37, Number: 2574
> 2008-07-15 10:25:10.378 0E,00,00,0A,0E,00,00,00,17,2F,44,3A,2F,46,54,50,2F,69,74,6D,70,2F,46,6F,6C,
> 2008-07-15 10:25:10.378 64,65,72,6E,61,6D,65,00,00,00,00,02,
. 2008-07-15 10:25:10.378 Sent 41 bytes
. 2008-07-15 10:25:10.378 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:25:10.378 Looking for network events
. 2008-07-15 10:25:10.378 Timeout waiting for network events
. 2008-07-15 10:25:10.378 Waiting for another 4 bytes
. 2008-07-15 10:25:10.378 Looking for incoming data
. 2008-07-15 10:25:10.394 Detected network event
. 2008-07-15 10:25:10.394 Enumerating network events for socket 596
. 2008-07-15 10:25:10.394 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:25:10.394 Handling network read event on socket 596 with error 0
. 2008-07-15 10:25:10.394 Received 43 bytes (0)
. 2008-07-15 10:25:10.394 Read 4 bytes (39 pending)
. 2008-07-15 10:25:10.394 Read 39 bytes (0 pending)
< 2008-07-15 10:25:10.394 Type: SSH_FXP_STATUS, Size: 39, Number: 2574
< 2008-07-15 10:25:10.394 65,00,00,0A,0E,00,00,00,0B,00,00,00,14,46,69,6C,65,20,61,6C,72,65,61,64,79,
< 2008-07-15 10:25:10.394 20,65,78,69,73,74,73,2E,00,00,00,02,65,6E,
< 2008-07-15 10:25:10.394 Status/error code: 11, Message: 2574, Server: File already exists., Language: en
. 2008-07-15 10:25:10.394 Asking user:
. 2008-07-15 10:25:10.394 Error creating folder '/D:/FTP/itmp/Foldername/'. ("File already exists.
. 2008-07-15 10:25:10.394 Error code: 11
. 2008-07-15 10:25:10.394 Error message from server (en): File already exists.
. 2008-07-15 10:25:10.394 Request code: 14")
. 2008-07-15 10:25:10.628 Session upkeep
. 2008-07-15 10:25:10.628 Looking for network events
. 2008-07-15 10:25:10.628 Timeout waiting for network events
. 2008-07-15 10:25:11.128 Session upkeep
. 2008-07-15 10:25:11.128 Looking for network events
. 2008-07-15 10:25:11.128 Timeout waiting for network events
. 2008-07-15 10:25:11.628 Session upkeep
. 2008-07-15 10:25:11.628 Looking for network events
. 2008-07-15 10:25:11.628 Timeout waiting for network events
. 2008-07-15 10:25:12.128 Session upkeep
. 2008-07-15 10:25:12.128 Looking for network events
. 2008-07-15 10:25:12.128 Timeout waiting for network events
. 2008-07-15 10:25:12.628 Session upkeep
. 2008-07-15 10:25:12.628 Looking for network events
. 2008-07-15 10:25:12.628 Timeout waiting for network events
. 2008-07-15 10:25:12.988 Listing directory "/D:/FTP/itmp".
> 2008-07-15 10:25:13.003 Type: SSH_FXP_OPENDIR, Size: 21, Number: 3083
> 2008-07-15 10:25:13.003 0B,00,00,0C,0B,00,00,00,0C,2F,44,3A,2F,46,54,50,2F,69,74,6D,70,
. 2008-07-15 10:25:13.003 Sent 25 bytes
. 2008-07-15 10:25:13.003 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:25:13.003 Looking for network events
. 2008-07-15 10:25:13.003 Timeout waiting for network events
. 2008-07-15 10:25:13.003 Waiting for another 4 bytes
. 2008-07-15 10:25:13.003 Looking for incoming data
. 2008-07-15 10:25:13.019 Detected network event
. 2008-07-15 10:25:13.019 Enumerating network events for socket 596
. 2008-07-15 10:25:13.019 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:25:13.019 Handling network read event on socket 596 with error 0
. 2008-07-15 10:25:13.019 Received 17 bytes (0)
. 2008-07-15 10:25:13.019 Read 4 bytes (13 pending)
. 2008-07-15 10:25:13.019 Read 13 bytes (0 pending)
< 2008-07-15 10:25:13.019 Type: SSH_FXP_HANDLE, Size: 13, Number: 3083
< 2008-07-15 10:25:13.019 66,00,00,0C,0B,00,00,00,04,01,00,00,00,
> 2008-07-15 10:25:13.019 Type: SSH_FXP_READDIR, Size: 13, Number: 3340
> 2008-07-15 10:25:13.019 0C,00,00,0D,0C,00,00,00,04,01,00,00,00,
. 2008-07-15 10:25:13.019 Sent 17 bytes
. 2008-07-15 10:25:13.019 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:25:13.019 Looking for network events
. 2008-07-15 10:25:13.019 Timeout waiting for network events
. 2008-07-15 10:25:13.019 Waiting for another 4 bytes
. 2008-07-15 10:25:13.019 Looking for incoming data
. 2008-07-15 10:25:13.035 Detected network event
. 2008-07-15 10:25:13.035 Enumerating network events for socket 596
. 2008-07-15 10:25:13.035 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:25:13.035 Handling network read event on socket 596 with error 0
. 2008-07-15 10:25:13.035 Received 221 bytes (0)
. 2008-07-15 10:25:13.035 Read 4 bytes (217 pending)
. 2008-07-15 10:25:13.035 Read 217 bytes (0 pending)
< 2008-07-15 10:25:13.035 Type: SSH_FXP_NAME, Size: 217, Number: 3340
< 2008-07-15 10:25:13.035 68,00,00,0D,0C,00,00,00,03,00,00,00,0A,46,6F,6C,64,65,72,6E,61,6D,65,00,00,
< 2008-07-15 10:25:13.035 00,BD,02,00,00,00,00,00,00,00,00,00,00,00,04,75,73,65,72,00,00,00,05,67,72,
< 2008-07-15 10:25:13.035 6F,75,70,00,00,41,B6,00,00,00,00,48,7C,B3,1C,00,00,00,00,48,7C,B3,1C,00,00,
< 2008-07-15 10:25:13.035 00,00,48,7C,B3,1C,00,00,00,09,72,68,69,6E,6F,73,6F,66,74,00,00,00,BD,02,00,
< 2008-07-15 10:25:13.035 00,00,00,00,00,00,00,00,00,00,04,75,73,65,72,00,00,00,05,67,72,6F,75,70,00,
< 2008-07-15 10:25:13.035 00,41,B6,00,00,00,00,48,7C,4B,0E,00,00,00,00,48,77,84,62,00,00,00,00,48,77,
< 2008-07-15 10:25:13.035 AB,2C,00,00,00,03,53,51,45,00,00,00,BD,02,00,00,00,00,00,00,00,00,00,00,00,
< 2008-07-15 10:25:13.035 04,75,73,65,72,00,00,00,05,67,72,6F,75,70,00,00,41,B6,00,00,00,00,48,7C,4B,
< 2008-07-15 10:25:13.035 0E,00,00,00,00,47,E3,D3,5B,00,00,00,00,48,44,EB,F0,
> 2008-07-15 10:25:13.035 Type: SSH_FXP_READDIR, Size: 13, Number: 3596
> 2008-07-15 10:25:13.035 0C,00,00,0E,0C,00,00,00,04,01,00,00,00,
. 2008-07-15 10:25:13.035 Sent 17 bytes
. 2008-07-15 10:25:13.035 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:25:13.035 Looking for network events
. 2008-07-15 10:25:13.035 Timeout waiting for network events
. 2008-07-15 10:25:13.035 Read file 'Foldername' from listing
. 2008-07-15 10:25:13.035 Read file 'rhinosoft' from listing
. 2008-07-15 10:25:13.035 Read file 'SQE' from listing
. 2008-07-15 10:25:13.035 Waiting for another 4 bytes
. 2008-07-15 10:25:13.035 Looking for incoming data
. 2008-07-15 10:25:13.050 Detected network event
. 2008-07-15 10:25:13.050 Enumerating network events for socket 596
. 2008-07-15 10:25:13.050 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:25:13.050 Handling network read event on socket 596 with error 0
. 2008-07-15 10:25:13.050 Received 35 bytes (0)
. 2008-07-15 10:25:13.050 Read 4 bytes (31 pending)
. 2008-07-15 10:25:13.050 Read 31 bytes (0 pending)
< 2008-07-15 10:25:13.050 Type: SSH_FXP_STATUS, Size: 31, Number: 3596
< 2008-07-15 10:25:13.050 65,00,00,0E,0C,00,00,00,01,00,00,00,0C,45,6E,64,20,6F,66,20,66,69,6C,65,2E,
< 2008-07-15 10:25:13.050 00,00,00,02,65,6E,
< 2008-07-15 10:25:13.050 Status/error code: 1
> 2008-07-15 10:25:13.050 Type: SSH_FXP_CLOSE, Size: 13, Number: 3844
> 2008-07-15 10:25:13.050 04,00,00,0F,04,00,00,00,04,01,00,00,00,
. 2008-07-15 10:25:13.050 Sent 17 bytes
. 2008-07-15 10:25:13.050 There are 0 bytes remaining in the send buffer
. 2008-07-15 10:25:13.050 Looking for network events
. 2008-07-15 10:25:13.050 Timeout waiting for network events
. 2008-07-15 10:25:13.128 Session upkeep
. 2008-07-15 10:25:13.128 Looking for network events
. 2008-07-15 10:25:13.128 Detected network event
. 2008-07-15 10:25:13.128 Enumerating network events for socket 596
. 2008-07-15 10:25:13.128 Enumerated 1 network events making 1 cumulative events for socket 596
. 2008-07-15 10:25:13.128 Handling network read event on socket 596 with error 0
. 2008-07-15 10:25:13.128 Received 31 bytes (0)
. 2008-07-15 10:25:13.628 Session upkeep
. 2008-07-15 10:25:13.628 Looking for network events
. 2008-07-15 10:25:13.628 Timeout waiting for network events
. 2008-07-15 10:25:14.128 Session upkeep
. 2008-07-15 10:25:14.128 Looking for network events
. 2008-07-15 10:25:14.128 Timeout waiting for network events
. 2008-07-15 10:25:14.628 Session upkeep
. 2008-07-15 10:25:14.628 Looking for network events
. 2008-07-15 10:25:14.628 Timeout waiting for network events
. 2008-07-15 10:25:15.128 Session upkeep
. 2008-07-15 10:25:15.128 Looking for network events
. 2008-07-15 10:25:15.128 Timeout waiting for network events
. 2008-07-15 10:25:15.628 Session upkeep
. 2008-07-15 10:25:15.628 Looking for network events
. 2008-07-15 10:25:15.628 Timeout waiting for network events
. 2008-07-15 10:25:16.128 Session upkeep
. 2008-07-15 10:25:16.128 Looking for network events
. 2008-07-15 10:25:16.128 Timeout waiting for network events
. 2008-07-15 10:25:16.629 Session upkeep
. 2008-07-15 10:25:16.629 Looking for network events
. 2008-07-15 10:25:16.629 Timeout waiting for network events
. 2008-07-15 10:25:17.129 Session upkeep
. 2008-07-15 10:25:17.129 Looking for network events
. 2008-07-15 10:25:17.129 Timeout waiting for network events
. 2008-07-15 10:25:17.629 Session upkeep
. 2008-07-15 10:25:17.629 Looking for network events
. 2008-07-15 10:25:17.629 Timeout waiting for network events
. 2008-07-15 10:25:18.129 Session upkeep
. 2008-07-15 10:25:18.129 Looking for network events
. 2008-07-15 10:25:18.129 Timeout waiting for network events
. 2008-07-15 10:25:18.629 Session upkeep
. 2008-07-15 10:25:18.629 Looking for network events
. 2008-07-15 10:25:18.629 Timeout waiting for network events
. 2008-07-15 10:25:19.129 Session upkeep
. 2008-07-15 10:25:19.129 Looking for network events
. 2008-07-15 10:25:19.129 Timeout waiting for network events
. 2008-07-15 10:25:19.629 Session upkeep
. 2008-07-15 10:25:19.629 Looking for network events
. 2008-07-15 10:25:19.629 Timeout waiting for network events
. 2008-07-15 10:25:20.129 Session upkeep
. 2008-07-15 10:25:20.129 Looking for network events
. 2008-07-15 10:25:20.129 Timeout waiting for network events
. 2008-07-15 10:25:20.629 Session upkeep
. 2008-07-15 10:25:20.629 Looking for network events
. 2008-07-15 10:25:20.629 Timeout waiting for network events
. 2008-07-15 10:25:20.894 Closing connection.
. 2008-07-15 10:25:20.894 Sending special code: 12
. 2008-07-15 10:25:20.894 Sent EOF message
. 2008-07-15 10:25:20.894 Selecting events 0 for socket 596
bkrontz
The debug level 2 log that I added was based on this client structure: C:\Foldername\Subfoldername. Which was to be transferred to the ftp server where username bkrontzadmin's home directory is: C:\FTP\ITMP\
Foldername and Subfoldername both have 3 text files that are not empty.
Re: Error Code: 24 - Specified File is a Directory
Your server seems not to allow changing permissions of directories.
WinSCP cannot avoid doing that unfortunately.
This issue has been added to tracker.
