Keepalive option for script
jprealini
Bs. As., Argentina
Hi!!
First of all, thanks for your work, this little program has been a great help...
I am trying to solve this issue. I am using winscp to connect to a Linux server from a Windows2003 server machine. When I connect with the GUI interface, the connection process takes about 25 seconds (the server I am connecting to is a production server with a lot of traffic)... but it finally connects.
When I try to connect and download a file using a script, the connection drops past 3 seconds...
Is there a way to use a keepalive option in the script???
Here is the script I am using:
option batch on
open intpap:123qaz@10.210.50.67
cd /home/intpap
option transfer ascii
get XXINVREP.txt C:
close
Thanks in advanced!!
Re: Keepalive option for script
When does it drop? During file transfer?
What makes you think keepalives would help?
jprealini
Bs. As., Argentina
Keepalive
Hi.. thanks for such a quick reponse...
Then connection drops when it reaches the authentication process. As I mentioned, connecting from the GUI interface, the connection process pauses right there (in the authentication, where it says "Authenticating with pre-entered password"), then I get a message that says: "Host has not answered for more than 15 seconds... still waiting"... Then I leave it alone, and after 15 more seconds, maybe more, the connection is established...
But when I run from the script, I see the "Authenticating with pre-entered...", and after 3 or 4 seconds, the connection closes, and the file is not transfered...
If you think keepalive won't help, how do you think I can solve this?? I tried setting batch and confirm both on, but it didn't work...
Thanks again
jprealini
Bs. As., Argentina
Re: Keepalive
Please post a log file both for GUI and script. Use the latest version (4.1.4 beta).
Hi... this is the log file I get connecting from the GUI interface:
WinSCP Version 4.1.4 (Build 407) (OS 5.2.3790 Service Pack 2)
Login time: Lunes, 14 de Julio de 2008 a.m. 11:12:40
Session name: intpap@10.210.50.67
Host name: 10.210.50.67 (Port: 22)
User name: intpap (Password: Yes, Key file: No)
Tunnel: No
Transfer Protocol: SFTP (SCP)
Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
Proxy: none
SSH protocol version: 2; Compression: No
Bypass authentication: No
Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
SSH Bugs: -,-,-,-,-,-,-,-
SFTP Bugs: -,-
Return code variable: Autodetect; Lookup user groups: Yes
Shell: default, EOL: 0
Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
Local directory: default, Remote directory: home, Update: No, Cache: Yes
Cache directory changes: Yes, Permanent: Yes
DST mode: 1
Looking up host "10.210.50.67"
Connecting to 10.210.50.67 port 22
Server version: SSH-1.99-OpenSSH_3.9p1
We claim version: SSH-2.0-WinSCP_release_4.1.4
SSPI: acquired credentials for: Administrador@PAPTUC
Cannot convert IP address to SPN: DNS is not trusted
GSSKEX disabled:
Using SSH protocol version 2
Doing Diffie-Hellman group exchange
Doing Diffie-Hellman key exchange with hash SHA-1
Host key fingerprint is:
ssh-rsa 1024 28:86:2b:cd:04:1f:f0:fb:78:13:21:9b:6b:f2:21:64
Initialised AES-256 SDCTR client->server encryption
Initialised HMAC-SHA1 client->server MAC algorithm
Initialised AES-256 SDCTR server->client encryption
Initialised HMAC-SHA1 server->client MAC algorithm
Using username "intpap".
Prompt (6, SSH password, , &Password: )
Using stored password.
Sent password
Waiting for data timed out, asking user what to do.
Asking user:
Host has not answered for 15 seconds.
Wait for another 15 seconds? ()
Tunnel: No
Proxy: none
SFTP Bugs: -,-
DST mode: 1
GSSKEX disabled:
Sent password
Asking user:
Data has arrived, closing query to user.
Access granted
Opened channel for session
Started a shell/command
Using SFTP protocol.
Doing startup conversation with host.
Type: SSH_FXP_INIT, Size: 5, Number: -1
Type: SSH_FXP_VERSION, Size: 5, Number: -1
SFTP version 3 negotiated.
We believe the server has signed timestamps bug
We will use UTF-8 strings for status messages only
Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
Getting current directory name.
Getting real path for '.'
Type: SSH_FXP_REALPATH, Size: 10, Number: 16
Type: SSH_FXP_NAME, Size: 45, Number: 16
Real path is '/home/intpap'
Listing directory "/home/intpap".
Type: SSH_FXP_OPENDIR, Size: 21, Number: 267
Type: SSH_FXP_HANDLE, Size: 13, Number: 267
Type: SSH_FXP_READDIR, Size: 13, Number: 524
Type: SSH_FXP_NAME, Size: 1695, Number: 524
Type: SSH_FXP_READDIR, Size: 13, Number: 780
Type: SSH_FXP_STATUS, Size: 28, Number: 780
Status/error code: 1
Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
Startup conversation with host finished.
Access granted
And this is a log I get for a connection that works fine. I thought I'd post it so you can have a reference....
Login time: Lunes, 14 de Julio de 2008 a.m. 11:15:20
Session name: intpap@10.210.50.65
Host name: 10.210.50.65 (Port: 22)
Tunnel: No
Proxy: none
SFTP Bugs: -,-
DST mode: 1
Looking up host "10.210.50.65"
Connecting to 10.210.50.65 port 22
GSSKEX disabled:
ssh-rsa 1024 22:36:6b:d2:e8:f8:ee:0a:66:ca:01:81:f7:60:38:d3
Keyboard-interactive authentication refused
Sent password
Access granted
Type: SSH_FXP_NAME, Size: 12601, Number: 524
Type: SSH_FXP_NAME, Size: 12809, Number: 780
Type: SSH_FXP_READDIR, Size: 13, Number: 1036
Type: SSH_FXP_NAME, Size: 12809, Number: 1036
Type: SSH_FXP_READDIR, Size: 13, Number: 1292
Type: SSH_FXP_NAME, Size: 4213, Number: 1292
Type: SSH_FXP_READDIR, Size: 13, Number: 1548
Type: SSH_FXP_STATUS, Size: 28, Number: 1548
Type: SSH_FXP_CLOSE, Size: 13, Number: 1796
Tunnel: No
Proxy: none
SFTP Bugs: -,-
DST mode: 1
GSSKEX disabled:
Sent password
Access granted
Thanks for your help
jprealini
Bs. As., Argentina
Logs
Sorry for not being to clear... These are only two logs... The first one (in red) is the log for the connection that is not working... Next (in blue) is the one for the connection that works...
Anyway, I suspect there is a routing problem here... I am talking to the guys that administer our gateway so they can open a route to this server... If this doesn't work, I'll let you know.
Tunnel: No
Proxy: none
SFTP Bugs: -,-
DST mode: 1
GSSKEX disabled:
Sent password
Asking user:
Tunnel: No
Proxy: none
SFTP Bugs: -,-
DST mode: 1
GSSKEX disabled:
Sent password
Asking user:
Access granted
Access granted
Tunnel: No
Proxy: none
SFTP Bugs: -,-
DST mode: 1
GSSKEX disabled:
Sent password
Access granted
Tunnel: No
Proxy: none
SFTP Bugs: -,-
DST mode: 1
GSSKEX disabled:
Sent password
Access granted
