"Open session in new window"
Ricardo
Ricardo avatar
Using Shift and clicking a saved session in order to "open session in new window" is not working for sessions saved inside folders.
It returns the error "Host does not exist".
Version 4.1.4 (build 407);
"Commander" interface;
Tested on XP+SP3.
Ricardo
Ricardo avatar
"Duplicate session in new window"
I think the same is happening when we want to "duplicate session in new window" by using Shift while clicking the "Duplicate session" button.
The new process will start with this wrong parameter:
"C:\Program Files\WinSCP\WinSCP.exe" "_!_duplicate"
Tested with version 4.1.7 on Vista.
Btw, what is the parameter to start WinSCP and open a saved Location Profile?
Re: "Duplicate session in new window"
Thanks again. This issue has been added to tracker. It seems that it does not work at all this time, not only with sessions in folder.
You cannot do that.
