file associated with this document has been moved outside..
Verichip
CA
trying to save a file on the folder, wont let me save. temp directory is system default.
any ideas?
thanks
Re: file associated with this document has been moved outside..
Sorry, I'm not sure if I understand what you are doing.
Are you uploading a file to remote directory? Can you post an exact error message? Or even better, a log file?
