can not force closing winscp window
cbs
Hello, i'm using winscp in command-line and when winscp.exe can't connect to the server (while connection is out for example) I can't close winscp window and I can't close winscp application through my application.
Thanks for your suggestion.
cbs
Re: can not force closing winscp window
What does WinSCP do whwn you cannot close it?
Cosole display is :
batch on
confirm off
Searching for host...
Can you provide me your email address, so I can send you a debug version of WinSCP to track the problem? If you do not want to post the address here, you can send me an email. You will find it (if you log in) in my forum profile. Thanks.
cbs
Did you received my email address ?
regards
regards
I have already sent you a debug version.
