I am using SSH-2 and SFTP-3 and do not see "Newer and update
msmedley
Jacksonville, FL
I think I am using the proper protocols. I looked in Server/Protocol Information dialog. I do not see "Newer and updated file(s) only" options anywhere. I don't see a "More button" either. Please help. I love this tool. First time trying it for syncing.
Re: I am using SSH-2 and SFTP-3 and do not see "Newer and up
The option cannot be used for synchronization. It is used with file transfer only (well as kind of syncing). You will find it here anyway.
What version of WinSCP are you using?
msmedley
I finally found it by pressing F5. I have *never* did a file copy using F5 -- only drag and drop! That's why I never saw this dialog before. It might be a good idea to include this dialog in Options | Preferences too. ;)
