Resume "not possible" but manually it works...
bitboy0
Germany - Ladenburg
I tried the latest stable first.. then the beta... same result:
If I transfer som bigger files (using unsecured passive FTP) in the copy windows appears "wiederaufetzen: geht nicht" translatetd "Resume: not possible" ...
The Server is debian/proftp with Resume enabled for upload and download.
In fakt I CAN resume! But WINSCP allways display that's not possible. So if I stop WINSCP while transfer some MB and start again then I can choose if I like to delete the uploaded part and start from the begin or if I like to resume (wiederaufsetzen) ... this works fine.
It would be fine If the program would show this correct.
regards
Re: Resume "not possible" but manually it works...
I know that the indicator is confusing. It says if WinSCP is able to resume the transfer automatically. E.g. if connection is dropped. It does not say if it is possible at all. I'll remove the indicator in the next major version.
