Display progress bar in command line ?
Cbs
i'm using winscp in command line in my application.
It is possible to know what's is doing winscp to display a progress bar for example or the name of the file is copying during the synchronization ?
After having open the session with /console option, it's impossible to send another command to winscp without "winscp.exe" or "winscp.com".
Sorrye for my English...
Re: Display progress bar in command line ?
You can capture output of winscp.com and interpret it. But it won't work if you want to display progress of transfer of single file.
filledvoid
Would it be possible to add a command line option to winscp.com that would cause it to output each progress line separately, instead of waiting until the file is done before writing the line? For example, adding the /progressoutput option would result in output something like this (fake numbers):
winscp.com /progressoutput /script=syncscript.txt
Active session: [1] user@somewhere
Comparing...
Local 'C:\SomeDir' <= Remote '/home/user/somedir'
Synchronizing...
SomeFile.bin | 0 KiB | 0.0 KiB/s | binary | 0%
SomeFile.bin | 150 KiB | 75.2 KiB/s | binary | 5%
SomeFile.bin | 300 KiB | 76.2 KiB/s | binary | 10%
SomeFile.bin | 500 KiB | 74.2 KiB/s | binary | 15%
This way scripts can parse each progress line and do something useful while the file is downloading.
fv
