Scripts
scuba79
Scripts
I'm trying to create a script to use with WinSCP. Where do I store the script (*.txt) file so when I try to use the command line option and define which script to use the program knows which script I'm talking about.
Thanks in advance.
Re: Scripts
Either store it to the same directory, where winscp.exe is. Or specify full path to script file in /script option.
