Copy HTTP URL? Add/modify context-menu shortcut?
VLM
Hi, I just downloaded and installed WinSCP a short while ago ... very glad I did!!! It's VERY fast and easy to use learn. I have 2 (hopefully) quick questions:
1. When I right-click on a file in the remote browser, under file Names I see
copy to clipboard
copy to clipboard (include paths)
copy URL to clipboard
The third option copies the sftp URL to the clipboard. Is there a way to copy the http URL to the clipboard?
2. On the context-menu under File Names, I notice that there is no shortcut for "copy URL to clipboard". I explored the UI and searched the archive, but I don't yet see how to add or modify a context-menu shortcut. Can this be done? How?
Thanks!
Re: Copy HTTP URL? Add/modify context-menu shortcut?
EDIT: There's extension for Generating HTTP URL.
...but I don't yet see how to add or modify a context-menu shortcut. Can this be done? How?
No.
VLM
BTW, you may be interested to know that SmartFTP does this, and it appears to work fine. I'm no programmer, so I don't comprehend the issues involved. I'm just letting you know, in case it's something you wish to follow up on.
Cheers!
I see. SmartFTP has global settings for that. You have to specify the same data as you need to specify in the script shown in the FAQ. Moreover there as the settings in SmartFTP are global, it can hardly work with multiple different servers. But if I find that more people would find it more user friendly, I can add similar function as SmartFTP has.
OK, I take this back. Apparently they have per-session settings for that.
VLM
Hope it's okay to pursue this just a bit further. What I do like about SmartFTP, in this instance, is their use of tabs to display diverse remote connections. In my experience, these can be to any server or combination of servers. Again, I'm speaking only as a user, without technical understanding. I mean only to share what I happen to like in this one instance.
OK, do you miss possibility to open more connections in one windows (WinSCP support that) or the tabs to switch between the connections? (WinSCP has different means to do so, e.g. the session combo box, see doc).
VLM
As I pause for a moment and think about this, I like (or would like) 2 things:
1. Full view of open connections. The tabs provide this jus a bit more obviously, in a visual sense, than does the session combo box. I realize this is entirely personal preference, and that there is no functional difference at all.
2. Ease of switching between using keyboard shortcuts. MS Outlook provide an example I happen to like. A user can press ctrl-1 or ctrl-2 to switch between the mail and calendar windows, similarly for the other windows (which I use much les frequently and therefore have not memorized the shortcuts).
Does this input help?
I see. This issue has been added to the tracker:
Issue 77 – Tab selector for sessions.
For a list of shortcuts you can use for switching between sessions, see:
https://winscp.net/eng/docs/ui_commander_key#tab_management
Parm
I did read the FAQs, and I tried looking into the custom commands but it appeared complicated for a novice user.
I had previously used SmartFTP, and its implementation of HTTP url copying was really good and easy to configure. Unfortunately, it ceased being freeware and I then switched to WinSCP.
Really liking it so far, only having two problems:
1) Can't copy HTTP urls to clipboard
2) My ftp connection drops out when inactive (I do have it set to keep active) and the pop-up reconnect prompt can be a little obtrusive
Other than that, it's working very well. :)
