Is there any way how to change the winscp.ini file location?
majkee
situation: WinSCP is installed on workstation, and domain policy prohibits users to modify anything on the disk c: where is winscp installed. Does exists any way or trick, how to change the winscp.ini file location, so users can store these in their profiles, and are able to save the used sessions for future use?
Thanks in advance for reply
Re: Is there any way how to change the winscp.ini file locat
WinSCP uses registry to store the configuration by default, so you should not have a problems with that. What version of WinSCP are you using?
Anyway, you can use /ini switch to change location of an INI file.
version is 4.0.7
can you state where in registry it is possible to edit the mentioned ini file location?
thanks in advance.
It cannot be set in registry. It is set by the /ini switch as mentioned above.
Please read documentation.
