Error when deleting files, help!
iJen
Hi!!
I need some help deleting the files, everytime i try to delete something this appears:
Command 'rm -f -r "MARIO.EXE"'
failed with return code 1 and error message
rm: MARIO.EXE: Permission denied.
Do I have to change the permissions? what can I do?
Thank you very much in advance!
Jenny
Re: Error when deleting files, help!
May be.
It is also possible that the file is being used atm. E.g. being .exe file, it may be running on the server.
I have change the protocol and i have been able to delete it
Thank u for your reply,anyways,and congs for your program!
