Button above "Close" half hidden when using Large Fonts
cthart
Nootdorp, The Netherlands
For some reason my laptop boots with large fonts when it's not connected to my large external monitor.
When I use WinSCP when it's in this large font mode, the button above "Close" is half hidden.
NB large fonts is not enabled using the large fonts option, but with 125% (120dpi) under advanced screen settings.
This bug is of course purely cosmetic, but it doesn't look good :-)
Cheers,
Colin
_________________
Oracle Database Specialist @ DataJini
Re: Button above "Close" half hidden when using Large Fonts
What version of WinSCP are you using? Have you tried the latest one? If you have, can you post a screenshot?
cthart
WinSCP 4.0.7
<invalid hyperlink removed by admin>[/img]
_________________
cthart
OK, can you try the latest beta version?
Ahah, it's fixed in beta 4.1.3, grand!
Thanks for a great product, we use it often at work. Our #1 requested feature would be to be able to initiate transfers between 2 remote servers, but I know that this is difficult to add :-)
Cheers,
Colin
_________________
