Passwording Directories on winSCP
Judes
I want to password certain directories inside my winSCP.
not on the website it's self..but inside where you update.
I want to keep certain section off limits to other who update with me on my website.
Is this possible?
Re: Passwording Directories on winSCP
If he/she is using different account, just make sure only you (your account) has permissions to the files/directores.
because currently we all use the same long on.
I do not your server. So I cannot advice you how to create separate accounts.
