connection refused with winscp 3.2.1 worked under 2.2.0
Butcher
I downloaded the newest Version and tried to connect to my server, the result was that it didn't work and I got a "connection refused" error. Then I tried with the old version and it worked fine. The settings are (as I have compared them) equal.
Same happens with every connection I tried, to several different servers.
Log with 3.2.1
. WinSCP Version 3.2.1 (Build 174)
. Login time: Dienstag, 26. August 2003 11:46:46
. Session name: secret
. Host name: secret (Port: 22)
. User name: secret (Password: Yes, Key file: No)
. Transfer Protocol: SCP
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes
. Ping interval: 60 sec (0 = off); Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: secret, Remote directory: secret, Update: No, Cache: Yes
. Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. Looking up host "secret"
. Connecting to secret port 22
. Attempt to close connection due to fatal exception:
* Network error: Connection refused
. Closing connection.
* (ESshFatal) Network error: Connection refused
And with the old version:
. WinSCP Version 2.2.0 (Build 122)
. Login time: Dienstag, 26. August 2003 11:47:58
. Host name:secret (Port: 22)
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: none
. Server version: SSH-1.99-OpenSSH_3.6.1p1 Debian 1:3.6.1p1-1
. We claim version: SSH-2.0-PuTTY-Local: Jan 26 2003 11:53:20
. Host key fingerprint is:
. ssh-rsa 1024 85:21:41:ba:9e:b7:ec:56:04:ff:a1:fe:e8:ca:22:7b
. Keyboard-interactive authentication refused
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Doing startup conversation with host (shell).
. Skipping host startup message (if any).
> echo "WinSCP: this is end-of-file:0"
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
. Trying "$?".
> echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$?" selected.
. Looking up current user groups.
> groups ; echo "WinSCP: this is end-of-file:$?"
< secret
. Following groups found:
Re: connection refused with winscp 3.2.1 worked under 2.2.0
Thanks for your report. I'll look at that. Can you try versions of WinSCP between 2.2 and 3.2.1 to find from which version the problem exists? You may download all versions from Sourceforge.
Also, please, try to connect with Putty.
Butcher
Tried different Versions, with all Versions the same thing (down to Version 2.2.3)
With putty the same thing
0.52 works
newer versions don't work
any idea?
Butcher
Found out what the problem was. I had the cisco vpn client installed and that seemed to make some problems, after removing it, it works perfectly.
Please report this to authors of Putty.
