server unexpectedly closed network connection
kimmyb
Canada
My son is receiving an error message "cannot connect to Youtube" on his ipod touch. I searched the web and was given some info on how to fix this problem. I was told to install the winSCP program to connect to the ipod. I had no problem connecting a few days ago, but now I receive the error message, "server unexpectedly closed network connection. I have the SSH installed on the ipod touch. Any suggestions?
Re: server unexpectedly closed network connection
I would suggest you to check log of the iPod's SSH server, if you are able to locate it. Otherwise you should better seek help on iPod-related forum.
