Invalid access to memory
shegiz
I use the latest version (4.1.2), and I've got this message almost every time when I start WINSCP.
I used 4.0.7 (I guess) previously, and I had the same problem, but I saw a BUG report, and the report said the bug fixed in 4.1.1. I think it is not.
If I just start my PC, usually it works, but when I start the program second time, the error comes up.
And after this error message, most of the functionality go dead.
If I can help ....
I use: MS Windows Vista Enterprise
Andras
Re: Invalid access to memory
Can you provide me your email address, so I can send you a debug version of WinSCP to track the problem? If you do not want to post the address here, you can send me an email. You will find it (if you log in) in my forum profile. Thanks.
