File sizes
radnix
File sizes
Hi :D,
What is the file size limit to upload/download for WinSCP? 100 meg, 200 meg....?
Thanks ahead .... :idea:
Re: File sizes
There is no exact limit, but :!: :
  • If you upload/download file in ASCII mode, it is first loaded into memory and converted. So you must have enough memory to fit whole file there. However this should not be problem, because text files don't get too large.
  • There's still old upload problem, that causes WinSCP to "send" file faster than your connection is able to really transfer it. This causes file to be cached in memory too, especially with slower connections. This happens only while uploading. The bug should be fixed with next version.
radnix
Re: File sizes
I understand, thanks! By the way, Klaus Birringer of Vienna has successfully chroot()'ed WinSCP using the instructions provided in post "WinSCP chroot()" thus duplicating my effort here. :D
Re: File sizes
Version 2.1 beta #119 should fix this problem.
