Putty path error and 'lookup user groups' greyed out
billmars
Just upgraded to 4.1.1 and am now getting 'error looking up user groups'.
I had this before and unchecked environment>scp/shell>lookup user groups.
Now when I go there I find this section greyed out, and 'lookup user groups' is ticked.
I can't untick it because it's greyed out.
Also the setting for the path to 'putty' keeps being reset to """"""C:\PuTTY\putty.exe""""""
and obviously doesn't work. Resetting the correct path does not 'stick', and the
above appears when WinSCP is restarted.
Any suggestions?
Re: Putty path error and 'lookup user groups' greyed out
Your have probably selected SFTP protocol with SCP fallback. In recent versions the SCP-specific options are disabled. To enable them, select SCP protocol explicitly.
Impossibility to save settings may be related to known bug in 4.1.1. Try to downgrade to 4.1.
billmars
Many thanks.
Selecting SCP brought back the greyed out settings and I was able to alter the 'groups' setting and all is as I remember it working before.
I'll wait for the next version which will hopefully rectify the path setting saving bug.
Thanks again.
guest
Can't find settings you mention
in your answer above you worte:
"To enable them, select SCP protocol explicitly."
In Version 4.1.7.413 I'm searching for this, but I don't find it. Is it to be done when I install the application?
Thanks in advance!
Re: Can't find settings you mention
Please read documentation. If that does not help, come back.
