"Abnormal program termination" error when closing the app
zero
Just installed v. 4.1.1. Build 385.
This version always gives me the error "Abnormal program termination" when I close the program (regardless what steps I perform after startup).
kapkap
Re: "Abnormal program termination" error when closing the ap
I also get every time this error message. I use WinXP SP2.
axiac
This also happens on Win2K (+SP4)
WinSCP 4.1.1 (Build 3.8.5)
Windows 2000, SP4
It displays the "Abnormal program termination" message when one quits the program (after the window closes). It happens always; when "WinSCP login" window is closed (without connecting to a profile) also when the Explorer-style or the NC-style window is closed (a connection is open, of course).
QA man
Re: The same problem
Note please, when this message appears
- winscp.RND file doesn't write
- added custom commands don't save
thank you
saxa wrote:
Martin, on the bug tracker you treat the error as resolved in 4.1.2... Where could we get it, please? :oops:
It will be released soon.
saxa
The memory could not be "read"
Mine closed with the following crash:
Interestingly, after clicking on "OK", I've got the same message once more, and then one more time. I thought, WinSCP couldn't close itself and wanted to use the Process Explorer to kill it, but I saw the error message only trice, and afterwards the WinSCP's process was closed.
I took this picture on W2K3 R1 SP2 32bit, English.
Daver
Same here on winxp-home sp2.
Faulting application winscp412.exe, version 4.1.2.388, faulting module winscp412.exe, version 4.1.2.388, fault address 0x00245ed4.
badboy
WinSCP crash (version 4.1.2 388)
I have a problem, when I close winscp. Program crashed only if configuration is saving in ini file. When configuration is in registry, program close without problems.
I have XP SP3, but winscp 4.0 and later working fine.
Tal56
Crash
I'm using the stand alone application and have the same problem. Winxp sp3 new install. I think it also has something to do with the writing to ini.
alexalex
same error in version 4.1.2
It worked fine for me until i insalled this version :( now it prints Abnormal program termination and after that 3 windows errors ( winscp has encountered an error.... ), one after another.
Exppecting another release.
thanks
