Using synchronize -criteria=time in a script fails
Hube
I am trying to use the following command in a script file (all one line).
synchronize -criteria=size remote D:\Recorded_TV /mnt/Scratch/Users/frontrow/Movies/tv
When I invoke the script:
WinSCP.com /script=E:\scripts\appleTV_cron.txt
I get the following message:
Too many parameters for command 'synchronize'.
If I remove the -criteria=time it works just fine.
This is an absolutely fabulous piece of software, Thank you so much for taking the time to create and maintain it.
Hube
Re: Using synchronize -criteria=time in a script fails
The -criteria switch is available since 4.1 beta only. I guess you are using an earlier version.
