How do I change the default local directory?
dwhs
dwhs avatar
Costa Rica
It's defaulted at my documents but I want to specify which folder.
_________________
Charley Y.
Web Host Pro
Hosting since 2001
dwhs
dwhs avatar
Costa Rica
Thanks, that helped. :D
I also wanted to change it for the existing 100 or so accounts in the software. So I tried the
If you want to change default local directory for all sessions,
But it does not change the other existing servers.
Is this option for when new servers are added?
Yes. And for those that does not have any default directory set.
You can switch to INI file and do replace in the INI file.
