brackets in the connection name after import from Putty
lupo
Version 4.1.0 (Build 375)
If you use brackets in the connection name (imported from Putty) it will interpreted as a directory.
Re: brackets in the connection name after import from Putty
Sorry I do not understand. Can you describe the problem in details?
