Some feature requests...
epp_b
Just some things I've thought of recently...
- set a default bookmark or directory profile to open at login (per-site setting)
- folders in stored sessions (recursing, not just one level)
- ability to dock log window (preferably beside the queue panel)
- option to store INI file in specified location
- option to change simultaneous parallel transfers on the fly via the queue toolbar
- remove limitation of 9 for maximum simultaneous transfers
- automatically reconnect (even when there is no active file transfer)
- option to suppress notification for lost connection when automatic reconnection is selected
Thanks!
Re: Some feature requests...
See documentation.
Switch to location profiles.
What do you use the log for?
Use command line parameter /ini.
What change do you mean?
OK, this has been added to tracker.
This is tracked already.
Do you mean the present notification of lost connection during transfer?
epp_b
No, you misunderstood me.
Maybe I should have said folders in the stored sessions list.
eg.:
<invalid hyperlink removed by admin> (<invalid hyperlink removed by admin>)
But with +/- signs by the folders and tree lines.
Monitoring and troubleshooting FTP commands.
OK, thanks!
Oh, OK. I searched the tracker before making this post, but I didn't see that item.
The "Max Simultaneous Transfers" option.
eg.:
Thanks!
Yes.
epp_b
Oh, forgot one thing: can we have the main WinSCP window (the first thing you see when you open WinSCP) resizable and for WinSCP to remember that size?
Thanks.
This is supported since 4.1 beta.
OK. Added to tracker. But with low priority, until more people ask for it.
OK, I see. Do you know that you can activate any background transfer by just double-clicking it, disreagrding the limit?
So you want to suppress the message box with countdown and reconnect immediatelly instead?
Because of stored session list?
